29th Apr 2016, 8:32 pm | #21 |
Re: Tin whiskers in transistors other than the AF11x series.
Hi.
I have experienced tin whiskers affecting an AC188 transistor from a Roberts R707. As has been pointed out, if the whiskers are to the case from either collector, base or emitter then the fault won't show up unless the case of the transistor is connected to anything. The AC188 in the R707 has an heat-sink fitted to it and this is bolted to the chassis. Out of interest, has anyone come across tin whiskers in an npn device such as AC127 or AC187? Regards Symon |
29th Apr 2016, 8:44 pm | #22 | |
Arguing whether it happens more on P-N-P or N-P-N transistors is akin to arguing whether positive- or negative-earth cars rusted faster (the answer is no). |
29th Apr 2016, 9:00 pm | #23 |
Hi.
That's very true about old unused AF11x transistors being afflicted by the tin whisker problem. I have a few in my collection of NOS transistors. Why is it that some really grotty looking and corroded used AF117s in my collection, taken from scrapped radios, appear to be absolutely fine whereas the clean looking NOS ones in plastic bags are affected? Regards Symon. Last edited by Philips210; 29th Apr 2016 at 9:07 pm. Reason: missing word |
29th Apr 2016, 9:24 pm | #24 |
What they look like on the outside makes no difference.
29th Apr 2016, 9:56 pm | #25 | ||
I fished it out of the bin and tested it again. It measure less than 20 ohms between the base connection and the case . So it looks likely that this particular AC128 has a tin whisker problem. |
29th Apr 2016, 10:09 pm | #26 |
Sounds like it needs to be cut open...
29th Apr 2016, 10:13 pm | #27 |
Any advice on that Lucien? Are there any nasty chemicals inside for example?
29th Apr 2016, 10:24 pm | #28 |
Hi.
We've been talking about cases of tin whiskers in European devices, notably Philips/Mullard but have there been any recorded cases of tin whiskers in the Japanese TO-1 style germanium transistors? Symon. |
29th Apr 2016, 11:38 pm | #29 |
I'd turn it very slowly in a lathe, to avoid any metal particles getting in that might be mistaken for whiskers, while minimising centrifugal force that might collapse them. I don't think there's anything harmful inside.
30th Apr 2016, 1:02 am | #30 |
I agree that there's unlikely to be anything toxic inside. For an amateur investigation you should be able to hold the transistor in a small vice and cut the top off with a Dremmel cutting disc or equivalent. This will contaminate the transistor, but it should be easy enough to distinguish between swarf/dust and tin whiskers using a microscope or even a strong hand lens.
30th Apr 2016, 4:27 am | #31 |
Do not assume only old parts affected. I am aware of problems on tin plated screening, like often used on rf screening on pcb modules. I once saw one metal screen with whiskers up to abou 6 mm long on something that was manufactured about 15 years previous. All whiskers that I have seen usually grow at an angle away from the surface.
Some intermittent faults have been caused by these whiskers. Low current areas around cmos are easily affected as well. With the miniaturised equipment today, expect to see more problems.
30th Apr 2016, 8:12 am | #32 |
Not to mention the use of unleaded solder- alloying with lead suppresses tin's tendency to grow whiskers. Critical applications were exempted but consumer items went unleaded. A cynic might venture that modern stuff has a short life-cycle anyway, so whiskering would assist in culling any survivors and make even the stubborn buy new things.
30th Apr 2016, 9:10 am | #33 | |
That's a fair point but it would still be interesting to find out if any npn devices have been found to be affected. From all the cases found so far they appear to have been pnp but then there's significantly less npn germanium devices than pnp types in existence anyway. Perhaps that's the reason why. Regards Symon. |
30th Apr 2016, 10:50 am | #34 |
30th Apr 2016, 11:24 am | #35 |
It's difficult to see why there would be a difference between PNP and NPN devices. If I understand correctly, the actual semiconductor structure isn't invoved in the whisker growth.
30th Apr 2016, 12:01 pm | #36 |
OK, I've opened up my suspect AC128 and pictures are shown below.
I am at the limits of my photographic skills and the technical spec of the camera but I think I can see whiskers. Last edited by Brian R Pateman; 30th Apr 2016 at 1:07 pm. Reason: I ment to show TWO pictures. |
30th Apr 2016, 12:17 pm | #37 |
You may well be right. It can be difficult to spot them if the grease is opaque. It may help if you use a single LED torch to shine a bright light into it.
30th Apr 2016, 12:35 pm | #38 |
Hi Paul,
I edited my post in which there is a better picture. My reason for editing should read "I meant to show TWO pictures". But the 30 minute editing time has expired so I can't correct it. |
30th Apr 2016, 1:37 pm | #39 |
That's an excellent couple of pictures, Colin - definitely whiskers there
I've had a few of these open themselves up, thanks to hairline cracks in the can - a gentle tug is all you need to pop the can off. Sadly, they didn't have whiskers, but I kept one to photograph (must get around to that!). I think the goo inside looks like silicone grease, but I can't really tell for sure. Amazing to think that it is the only medium to conduct the heat away from the junction... |
30th Apr 2016, 2:23 pm | #40 |
It might not be the end of the problems, tin is allotropic, it starts below 13 centigrade, white tin turns to pest tin, the resistivity of pest tin is many times higher than white tin so far as I'm aware.
I used to mine this stuff, the most abundant ore is Cassiterite (SnO2) When crushed it can be reduced with charcoal in the Rayburn (or owt else) to produce the metal, if you've got any lead kicking around it should be possible to make yer own solder Lawrence. |
