19th Jan 2018, 11:01 pm | #21 |
Re: Soldering Stations.
YEP- BUT think on- normal solder is 370 tops, but for radio blokes with higher O/P stages, there's a need for an iron to melt "higher temp solder" (AKA plumbing solder) , which works with "UP TO " 50 Watts coming out of aerial on TX ( Clansman 353 on band 1 comes to mind, where the TX coils are soldered in place with plumbing type solder). I'd suspect that on lower powered rigs, coil soldered problems occur if "normal " solder is used.
19th Jan 2018, 11:54 pm | #22 |
That's not quite the case. If you are using plumbing solder then you're only looking at 250 degrees or so which is well within the ability of a standard iron.
If you look at the clasman stuff you'll find it's probably normal 63/37 alloy or at best silver solder. The problem is you need a ridiculously high powered iron due to the thermal mass of the coils and transmission lines, not the desired tip temperature. The moment you touch the terminals the iron's heat gets dragged out and the iron can't replace it quick enough. Prime example; I disassembled a knackered Racal TUAAM with a 25W Antex firestick - ugh nightmare. Many years ago I had to put such things together and we used Pace irons. Starting at 550 degrees doesn't really solve that problem. Higher power iron with better temperature control is unconditionally always the answer. If the iron gets too cold then you will hold it on the joint and damage something. If the iron gets too hot then you'll damage something before you have completed the joint. If you look at the Weller WXP120 for example, it's a 120W iron with temperature control. That will keep 370 and quite happily work its way through some nasty jobs. Never gets too hot, never gets too cold. The cheap Chinese T12's as mentioned earlier in this thread are amazing in this respect as you get a roughly 50W iron with decent temperature control for pocket money and they eat every job up instantly. They are quite frankly, for the money, amazing. |
25th Jan 2018, 11:52 pm | #23 | |
27th May 2018, 8:13 pm | #24 |
Hi All
My wife came home from shopping at ALDI this morning. She walked into my workshop with a present for me. A WORTKZONE digital soldering station for which she paid a paultry £19.99. On opening up and using this afternoon it seems quite good for the money. Comes with 2 small reels of solder and 2 spare bits. Has anybody else had one of these? I think for twenty quid pretty good value even if it only has a lifetime of the bits. Regards Dave |
27th May 2018, 9:01 pm | #25 |
That does sound good value and the beauty of Aldi/Lidl stuff is the 3yr warranty.
I'm guessing its this one. There are more images if you click the arrows: https://www.aldi.co.uk/workzone-digi...83184201878400 |
28th May 2018, 8:41 am | #26 |
28th May 2018, 8:45 am | #27 |
That is interesting, thanks. I'll stick with my old but trusty Philips soldering station I think.
28th May 2018, 10:58 am | #28 |
My experience of Chinese solder stations is not good. I was given a new Maplin jobbie with a flash LCD display. OK, it worked, for about six months, and then the element went. The replacement iron lasted a day. this, quoth he, and went back to his Weller(s).
