Old 14th Nov 2017, 1:09 am   #1
ronbryan
Default Hunts CRB C & R Analyser updated circuit diagram
The Hunts CRB Capacitance and Resistance Analyser circuit diagram shown in the Operating Manual on the web has component values written on the drawing which have scanned badly. I have also identified a few differences in the circuit when compared to production unit s/n 1670.
I've marked up the original manual circuit with the correct component values and the voltage readings taken from my unit. I have also corrected the selenium rectifier polarity and the position of the 2k2 bridge resistor and have added the cathode resistor to the Y63 magic eye.
Ron
ronbryan is online now
Old 14th Nov 2017, 1:42 am   #2
dragonser
dragonser's Avatar
Default Re: Hunts CRB C & R Analyser updated circuit diagram
this is very good of you to take the time to do. I have one of these units to have a go at refurbishing ( repairing ? ) , but it has got put on the " round tuit pile "
Regards Peter B
dragonser is offline
Old 14th Nov 2017, 9:57 am   #3
Excellent.
Old 14th Nov 2017, 1:03 pm   #4
David G4EBT
David G4EBT's Avatar
Fantastic job Ron!
To illustrate just how helpful this is, until now, all that anyone wishing to repair or restore a Hunts CRB Analyser had to go on was the circuit from the manual, which is completely devoid of any values or voltages, and doesn't identify the type of neon indicator, as show below. It must have been quite a task for Ron to have checked everything out and to neatly annotate the circuit. I dare say that until now, many will have opened up a CRB with a view to restoring it, but just put it back together, for the lack on information.
No excuses now!
Name:	Hunts CRB Circuit (unmarked)_edited-1.jpg
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is online now
Old 14th Nov 2017, 7:15 pm   #5
Andrewausfa
Andrewausfa's Avatar
Very helpful Ron, thank you.
On the circuit you've noted 159k2 ohm, am I reading that correct as 159,002R? I just wondered about the precision
Mine is serial 925 so I will see if there are any 'original' differences in mine.
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 14th Nov 2017, 7:24 pm   #6
ronbryan
The precision resistor labelled as 159k2 is 159200 ohms 1%. I believe I have the notation correct, (e.g 1k2 is 1200 ohms, not 1002 ohms), but I did wonder whether I might cause confusion.
I will be interested to hear if your earlier unit has more differences.
Ron
Old 14th Nov 2017, 8:15 pm   #7
Andrewausfa
Hi Ron,
You're quite correct I was just reading it incorrectly. Now I've had mine apart I see what was meant. Here's the inside of mine and proof they were using Vishay MKT1813 in the 1940s..... There was a reason I didn't finish this a few years ago, possibly pondering what to do with the rectifier. I don't recall. I do note the original soldering isn't great.
Andrew
ID:	152267   Click image for larger version
ID:	152268   Click image for larger version
BVWS Member
