Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > General Vintage Technology > Where To Get Sets and Parts
Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay).
Old 28th Feb 2022, 9:50 am   #21
David G4EBT
David G4EBT's Avatar
Default Re: Vernier Caliper - cheap!
Silver Oxide cells needn't be expensive.
The Eunicell brand silver oxide 1.55V cells that I've used for the last few years presently cost 25 pence each - twenty for £4.95 post free. Renata on the other hand - if bought in packs of ten - are £1.50 each. I don't kid myself that the Eunicell ones will have the same capacity as Renata, but neither do think that Renata ones, at six times the price, will last six times as long. Even so, if top-branded Renata ones only lasted six months, that's 5p a week, which - even to impecunious guys like us - doesn't put much of a dent in our weekly outgoings.
'Poundmax' brand silver oxide ones cost £3.99 for ten post free - 40p each.
Sure, they're a bit dearer than pound-shop 1.5V alkalines, but not a lot.
You'll find both those offerings ('Eunicell' & 'Poundmax') today on eBay from well-established sellers with 100% positive feedback, much of which is from repeat customers such as myself.
The callipers I use the most are on my little metalworking lathe, where - if working to close tolerances - I have to keep stopping the lathe to check dimensions. I've 'kept tabs' on when I've had to replace the battery in those callipers and it's generally every 6 or 7 months, most recently in May 2021 and Jan 2022. The ones I use for my woodturning lathe, are used less often and last about a year. The pair I keep indoors and occasionally use for checking things like the gauge of wire, thickness of card last a bit longer, and I think benefit from being in a warmer environment.
Hope that's of interest.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 28th Feb 2022, 1:04 pm   #22
winston_1
I've got two vernier callipers, both from Lidl. The first one I bought many years ago for £9-99 and uses a LR44 cell. The second one I bought more recently in their reduced to clear box for £8-99. This one uses a CR2032 cell which lasts much longer.
winston_1 is offline
Old 28th Feb 2022, 3:35 pm   #23
wireman
Originally Posted by fetteler View Post
Originally Posted by wireman View Post
the specifications don't claim any accuracy which is a bit annoying. Does look like a bargain and for a stainless model as well.
Have you ever seen a set of calipers which were not stainless?
I certainly haven't!
Steve.
The plastic ones.
wireman is offline
Old 28th Feb 2022, 6:11 pm   #24
Bazz4CQJ
Bazz4CQJ's Avatar
I have some plastic ones that must be over 20 years old, and still working, but may not win prizes for great accuracy.
B
Bazz4CQJ is offline
Old 28th Feb 2022, 11:19 pm   #25
jamesperrett
I think the blue plastic ones came from Anglia Components. I found them really handy and perfectly accurate for measuring component sizes and the typical needs of an electronic engineer. Of course the mechanical engineers on our team had much better measuring instruments which I was usually allowed to borrow if I asked nicely.
jamesperrett is offline
Old 1st Mar 2022, 12:21 am   #26
fetteler
fetteler's Avatar
Steve.
The plastic ones.
Fair enough.
Steve.
Those who lack imagination cannot imagine what is lacking...
fetteler is online now
Old 1st Mar 2022, 12:21 pm   #27
kalee20
Just reading this, are we talking about the same things?
I have a pair of Mitotoyo vernier calipers, stainless steel, new from RS 20 years ago, working perfectly, never needed a new battery which is just as well because I can't seem to find the battery compartment!
I also have a pair of plastic Vernier calipers, the same applies for the battery, a freebie from Anglia Components. They look like a cheap toy, but they're dead easy to read to 0.1mm and fine for at least comparative measurements.
And I have a couple of sets of digital calipers. They're the easiest to read, these do need batteries, but (unless there's some clever wizardry in the sensing mechanism), Vernier they're not!
kalee20 is offline
Old 1st Mar 2022, 12:39 pm   #28
Nickthedentist
Nickthedentist's Avatar
I think "Vernier" is being used in its loosest (incorrect but quite common) way here!
Like others here, my cheapie, plastic, 0.1mm resolution ones are what I reach for for day-to-day workshop tasks. Similarly, some ancient Negretti and Zambra dial calipers when the digital ones aren't to hand or have run out of juice.
I've never had much luck with the Aldi ones in spite of others finding them fine. Both pairs I bought were faulty from new, never re-setting to zero repeatably.
I have digital and dial Mitotoyos for stuff which needs more precision.
My eyes aren't good enough for vernier scales unless I've got my glasses and really good lighting, so dad's Swedish "Tuna" brand set doesn't see the light of day much any more.
Nickthedentist is online now
Old 1st Mar 2022, 12:41 pm   #29
fetteler
fetteler's Avatar
............Vernier they're not!
Absolutely correct.
Steve.
Old 1st Mar 2022, 12:47 pm   #30
Nickthedentist
Steve.
The plastic ones.
And I have some 1950s "Tuna" ones which are very well made. but which tarnish very easily and need a polish to restore readability. Except they've been polished so much over the decades that the engraved lines and numbers are becoming fainter and fainter.
Old 1st Mar 2022, 1:21 pm   #31
It's not as bad as that, the measurement system uses a vernier type of mechanism, electrical moiré fringes.
Old 1st Mar 2022, 1:30 pm   #32
fetteler
fetteler's Avatar
Steve.
The plastic ones.
Yet again I say "Fair enough".
To give some context, the point of the (what I now realise to be a poorly worded) post I made was to illustrate that stainless is by far and away the most prolific material for digital verniers and that being stainless was not a particularly significant attribute to pick out in considering the Aldi offer to be a bargain.
To all those who took my post literally I would say that yes, I should have taken more care to get my meaning across. I often forget how literal some folks minds are - especially those of engineering and technical types.
FWIW I just discovered that Mitutoyo themselves make a carbon fibre version of their digital caliper.
Steve.
Old 1st Mar 2022, 1:30 pm   #33
Nickthedentist
I suppose it does, but the analogy had never occurred to me. Thank you!
Old 1st Mar 2022, 3:16 pm   #34
kalee20
The plastic ones.
Though to be literal, you did specify 'stainless' rather than 'Stainless' (capitalised) or 'stainless steel.' On that basis, I would argue that the plastic ones are 'stainless' and are therefore encompassed in your original post!
It's Nick who's provided the counter-example.
kalee20 is offline
Old 1st Mar 2022, 4:12 pm   #35
Paul Stenning
Administrator
Paul Stenning's Avatar
As we are getting that pedantic and off-topic it's time to close this.
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is online now
