Old 12th May 2020, 3:29 pm   #1
vinrads
Default Columbia radiogram restoration finish
I bought this from a friend in 2002. now it is finally finished .
it is a battery radio and a windup record player from the 1930's , the speaker grill was damaged part of it missing ,using the good part I made a template and constructed a new bit it's the curly bit at the bottom , the cabinet was stripped and given a few coats of patina, all the valves were ok replaced the paper capacitors and a few resistors ,got the radio working ,had a new dial made ,lost it for a while but found it eventually , the arm was missing on the deck , as luck would have it I had one , this I fitted with a X5H cartridge , I don't like to see shavings coming off my 78's , to get the tracking weight correct a spring was fitted at the rear of the arm , fun was had with the volume control as this only work's on the deck , eventually got it right , sounds pretty good ,from the push pull out put stage . Mick
PS the turntable is wrong , I have the correct one somewhere . Oh the motor was stripped and cleaned removing all the old grease yuk !
ID:	205615   Click image for larger version
ID:	205616   Click image for larger version
ID:	205617   Click image for larger version
vinrads is online now
Old 13th May 2020, 8:13 am   #2
unitaudio
Default Re: Columbia radiogram restoration finish
You'd never know the speaker grille had ever been damaged! Superb job.
Paul
...No, it's not supposed to pick up the World Service, it's not a radio!
unitaudio is online now
Old 13th May 2020, 12:33 pm   #3
Nickthedentist
Nickthedentist's Avatar
What a beautiful thing, and great work.
Nickthedentist is offline
Old 13th May 2020, 1:06 pm   #4
Whaam68
Beautiful job.....looks stunning!
Mike
Whaam68 is offline
Old 14th May 2020, 4:03 pm   #5
Petedox
Petedox's Avatar
Brilliant job Mick, it's great when you use many different skills, and then see them all come together.
Pete
Petedox is online now
Old 14th May 2020, 5:53 pm   #6
Heatercathodeshort
Heatercathodeshort's Avatar
Nice looking gram due to your hard work! Pre war grams are quite rare these days. They are great fun. John.
Heatercathodeshort is offline
Old 13th Jul 2020, 7:48 pm   #7
PaulR
PaulR's Avatar
I have just come across this thread. The 'gram looks really good. How did you manage to fit a modern cartridge into the arm?
Paul
PaulR is offline
Old 14th Jul 2020, 9:19 am   #8
vinrads
Hi Paul it was easy ,having removed the old pickup ,I screwed a small piece of ply to the arm using the holes left by the old pickup, then screwed the bracket to the ply, the ply has to be the correct thickness for the new cartridge, a spring was fitted to the rear of the arm a trial and error thing to get the correct tracking weight. Mick.
Old 14th Jul 2020, 9:38 am   #9
PaulR
PaulR's Avatar
Thank you Mick. I was thinking about something similar for the pickup on my McMichael 365 but the Garrard arm and head is the sort where the arm itself doesn't pull up and you turn over the head itself to change the needle. There isn't much scope for springs on that
Paul
PaulR is offline
