30th Jul 2019, 5:59 pm | #21 | |
Re: Hum in directly-heated single-ended output valves
I'm struggling a bit to believe that there is even a degree or two of valve-to-valve phase-shift variation at 100Hz going on. If there was, and if it affected the normal operation at all, then that would quickly become pretty exciting when the valve was operating at 20kHz, which it does do. But this experiment wouldn't be hard to carry out, so when I get a minute I might try it. Cheers, GJ
http://www.ampregen.com |
31st Jul 2019, 3:12 am | #22 |
As an extra comment just for hum issue, have you been able to confirm there is no hum induced due to any/all measurement equipment being mains ac powered?
Also I wouldn't discount the tuned choke method for reducing 100Hz B+ ripple, very simple, and likely providing more 100Hz attenuation than doubling the choke inductance. Is that choke suitably distant from the OT, and with the choke 'noisy input' terminal as the innermost winding terminal? |
31st Jul 2019, 8:21 am | #23 |
Some interesting stuff here about filament supply + hum - http://www.4tubes.com/Lost-Websites/...ch/humbal.html The lads over on DIY Audio usually use a dedicated filament supply, whose details I can't find at present or some of the articles I've read that pertain to your problem.
Will keep looking. Andy.
31st Jul 2019, 8:48 am | #24 | ||||
If the 50Hz component is null-outable to a satisfactory extent, then the residuals (100Hz etc) are down to non-linearities and it won't be possible to null them by the pot. You have to make the HT supply 'blameless' with lots of μF (even if not feasible in the final design, you can connect capacitance to prove a point). It sounds very inelegant, but if push comes to shove you may be able to cancel the hum (100Hz) by finding some 100Hz from a FW diode bridge, putting through a phase adjust RC network and an amplitude adjust pot, and injecting into the grid circuit to cancel what you can't fix. |
31st Jul 2019, 1:48 pm | #25 | |
Likewise there's not much leakage from the current HT choke since it's outside the amp altogether and connected just by a length of twisted pair. I've tried rotating its core axis to point along three orthogonal directions to see if that changes the measured 100Hz. But it doesn't. Thanks for reminding me about tuning the choke. A quick test has shown that I can get about 3dB improvement in the bad valve and rather more (not that I need it) in the good one. Perhaps this suggests that the higher level of 100Hz in the bad valve isn't coming completely from the HT ripple. So when I reduce that ripple a good deal something else is still contributing to the 100Hz in the bad valve. Cheers, GJ
31st Jul 2019, 3:47 pm | #26 |
Hi GJ,
I suppose it is quite possible that you are the first to observe the valve to valve difference and as such there isn’t an answer to your question. Tube cad article gives some insight into this type of problem and as often is the case, has a rabbit waiting in the hat. Eddie |
