6th Dec 2009, 6:29 pm | #21 |
Re: 1951 Bush TV22 405 line B/W Television set
The finishing touch would be a set of chassis labels.
https://www.vintage-radio.net/forum/...ht=tv22+labels |
7th Dec 2009, 5:13 pm | #22 |
That's one of the simplest chassis I've ever seen in a TV!
Nice job on the set, I wouldn't mind one like that myself! |
7th Dec 2009, 7:33 pm | #23 |
Very reliable for their time, were those chassis.
7th Dec 2009, 10:00 pm | #24 |
Does anyone else get 'bad enrypt dictionary' when trying to open the pdf files mentioned in #21 above?
Regards, Andy
Now where on earth did I remove that from? |
7th Dec 2009, 10:06 pm | #25 |
Both open OK here.
Jim |
8th Dec 2009, 12:09 am | #26 |
Andy
Have you tried first saving them to your desktop and then using open with Acrobat? Ian |
8th Dec 2009, 10:18 pm | #27 |
Hello,
Yes I've tried all ways up. I am using Acrobat 6 and I get this ...
8th Dec 2009, 10:55 pm | #28 |
Fine here using Foxit 3.1 and Acrobat 9.2. Won't open with Acrobat 5 so it look slike the PDF file uses features that are not compatible with some earlier readers. If you're still using Acrobat 6 I suggest you try Foxit. It's much smaller and faster than Acrobat 9.x.
http://www.foxitsoftware.com/pdf/rea...erstitial.html |
8th Dec 2009, 11:00 pm | #29 |
Hello Jeffrey,
Thank you fr your suggestion. I didn;'t want to mess with my Adobe since ity's also a writer as well as a reader. Is your Foxit suggestion a standalone, non interfering reader that will leave my Adobe alone? Regards, Andy
9th Dec 2009, 12:55 am | #30 |
9th Dec 2009, 8:48 am | #31 |
I have no problems with Acrobat 5 writer and Foxit running on the same system. I also have Acrobat 9.2 reader installed for those rare occasions where Foxit gets things wrong.
9th Dec 2009, 1:48 pm | #32 |
Please stay on topic folks. This thread is about Howard's TV22.
Paul |
20th Dec 2009, 3:41 pm | #33 |
Hello again, I printed those off but they're from a TV22 mark 2 and I think slightly different from those on the mark 1. The 'width' and 'horizontal form' labels are correct but the label on the EHT valve cover is different. The label on the dropper assembly is absent too. Does anyone have a jpg set of repro labels for a TV22 mark 1 please and I'll stick them on. Thanks. Howard |
21st Feb 2010, 12:02 am | #34 |
I've just found a pic of the TV22 as it was at the July 2009 WB auction ...
http://www.bvws.org.uk/auctions/phot...s/img_3450.jpg I'm still looking for some labels. Howard |
21st Feb 2010, 9:15 am | #35 |
Nice one, Howard. Were the above labels not what you wanted?
We had one in rental in the late 1960's that was used continuously; all it even needed was an annual replacement of the PL38 and PZ30. They (and all the Bushes from that era) are damn good sets!
Mike. |
21st Feb 2010, 2:52 pm | #36 |
Hello Mike,
No, the labels featured in the thread in the link above are from a later TV22 model, the labels in mine were as in this set .... http://bs.cyty.com/menschen/e-etzold...22_hinten3.jpg There was a label on the left-hand dropper assembly and two labels on the EHT valve cover which aren't on the above link. We will be performing the Darius mod soon which should reduce wear on the PL38. Howard |
10th Aug 2010, 6:43 pm | #37 |
Hello again,
At long last I've fitted labels inside the TV22 mark 1 ! Thanks Ian. Howard |
10th Aug 2010, 9:07 pm | #38 |
Well done howard, looks like polished chassis are the latest thing
But seriously, what a splendid job. I too am a radio only person, but seeing yor write-up, pushes me nearer & nearer to acquiring my first TV restoration project. I doff my cap to you, Regards Paul.
Cheers Paul. |
10th Aug 2010, 9:50 pm | #39 |
Hi Howard
Glad you thought the labels were OK. Looks good! Ian |
11th Aug 2010, 8:21 am | #40 |
I've not seen this thread before but the set looks really nice. It must be quite compact too if you can sit it on a 9" wall.
