11th Jun 2019, 3:37 pm | #21 |
Re: Testing capacitors for electrical leakage
If the source of water is a result of decomposition of the paper rather than moisture ingress, why is that 'waxies' tend to degrade whereas hermetically-sealed paper 'block' capacitors stay good? Is it just that block capacitors are typically military-grade and all the materials used, including the paper, are to a superior standard?
Andy |
11th Jun 2019, 3:45 pm | #22 |
They don't. That fact is very strong evidence against the ingress idea.
But they are made to a higher standard so often stay good for longer. It is all about the quality of the paper. Look at books, you see the same thing. I have a valve data book that I bought new when I was a child and now the paper is almost like ash. But I have much older books by decades that are still pretty good. I also suspect that the decomposition is auto-catalytic so once they start to go the process speeds up. |
11th Jun 2019, 4:32 pm | #23 |
I have a 250 volt Megger that I use to test capacitors for leakage. It works very well. the high voltage is current limited as well, so it will re-form some electrolytic caps too.
11th Jun 2019, 4:55 pm | #24 | |
I preliminary test every set I'm going to restore. Many times, restorers replace every component, only to find, the thing doesn't work at all after part replacement, where it worked somewhat before. More later, Gentlemen! Dave. |
11th Jun 2019, 5:02 pm | #25 |
An all to familiar story often repeated in the forums. I guess some people have no technical knowledge at all and assume that replacing all passive components will get a piece of equipment working. All too often it doesn't.
