Old 1st Jun 2019, 12:59 pm   #1
FERNSEH
FERNSEH's Avatar
Default Ekco TMB272. Patterning on picture.
Been repairing an Ekco TMB272 mains-battery TV set.
One of the faults encountered was patterning on the picture. The fault was solved by replacing the screen grid decoupling capacitors in the sound IF amplifier. Strangely, the sound was OK with the faulty capacitors.
Last year I experienced a similar fault in a Murphy V410A.
https://www.vintage-radio.net/forum/...y+V410A&page=2
DFWB.
ID:	184272   Click image for larger version
FERNSEH is offline
Old 1st Jun 2019, 1:42 pm   #2
Peter.N.
Default Re: Ekco TMB272. Patterning on picture.
Its very easy to be mislead, well done. I remember an early Murphy TV that if the focus control had reached the end of its travel - you replaced the sound output valve! Focus coil in series with the HT feed.
Peter
Peter.N. is offline
Old 1st Jun 2019, 2:28 pm   #3
Jac
Jac's Avatar
Excellent repair David.
These faults can be very misleading (at least for me).
Jac
Jac is offline
Old 1st Jun 2019, 5:13 pm   #4
FERNSEH
FERNSEH's Avatar
Peter.N wrote: "Its very easy to be mislead, well done. I remember an early Murphy TV that if the focus control had reached the end of its travel - you replaced the sound output valve! Focus coil in series with the HT feed."
The Murphy V180 is like that.
Hello Jac,
One could have easily been mislead into thinking the patterning fault was in the vision IF amplifiers and in fact the 6F1 valve screen grid decoupling capacitors also required replacement. The offending 0.003mfd capacitors were those brown ones made by Hunts.
DFWB.
FERNSEH is offline
Old 1st Jun 2019, 5:42 pm   #5
Jac
Jac's Avatar
Thanks David,
What did you use as replacement decoupling capacitors?
Someday I have to restore my TMB272 and TX275.
Jac
Jac is offline
Old 1st Jun 2019, 7:47 pm   #6
Tazman1966
Tazman1966's Avatar
What a bright and pin sharp picture! Excellent CRT in that and nice linearity too.
All the very best,
Tas
Tazman1966 is offline
Old 1st Jun 2019, 11:11 pm   #7
FERNSEH
FERNSEH's Avatar
Jac wrote: "What did you use as replacement decoupling capacitors?
Someday I have to restore my TMB272 and TX275."
Hello Jac,
I've sent you a PM.
DFWB.
FERNSEH is offline
Old 4th Jun 2019, 7:54 pm   #8
Malcolm G6ANZ
Malcolm G6ANZ's Avatar
I rarely comment on TV's as my knowledge is minimal. A question though, did the wavey lines change with the sound? It looks like the photo was taken with a test tone would the lines be different with speech or music.
Malcolm
Malcolm G6ANZ is offline
Old 5th Jun 2019, 9:25 am   #9
Restoration73
Restoration73's Avatar
I'm doing two of these here. I've noted that it is important the 3.5MHz trap is set
correctly - manual says short trimmer C40 (V3 anode) and adjust L33 (V10 cathode)
for minimum dot pattern. Audio tone for sound modulation. Trimmer C67 will also
have some some effect.
Restoration73 is offline
