Old 14th Jun 2019, 10:51 pm   #1
Diniz Diniz
Diniz Diniz's Avatar
Default 4 leg capacitor in Saba Sabine radio
Hello,
I am wondering if I can replace this four leg capacitor ( rated 0.025uF) for two capacitors (same size)?
Thanks in advance
Diniz, Portugal
Diniz Diniz is offline
Old 14th Jun 2019, 10:59 pm   #2
Default Re: 4 leg capacitor in Saba radio
Model number of the receiver, circuit reference?
Old 14th Jun 2019, 11:10 pm   #3
Diniz Diniz
Saba Sabine
Old 14th Jun 2019, 11:18 pm   #4
Andrewausfa
Andrewausfa's Avatar
Diniz, which Sabine? M, L, 12 etc ?
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 14th Jun 2019, 11:43 pm   #5
Diniz Diniz
The back cover makes no reference to the model, but I believe is Sabine M
Old 14th Jun 2019, 11:48 pm   #6
Diniz Diniz
My mistake, probably is C71 of Sabine L
Old 15th Jun 2019, 12:04 am   #7
Andrewausfa
Looks like it is 'special' capacitor with an RF screen/shield, I've had a couple myself in German sets. I would check the extra earth wires aren't also used as ground points for other connections in the circuit, if not just stick a 22nF capacitor in there.
Let's see what others think as well.
Andrew
BVWS Member
Old 15th Jun 2019, 7:19 am   #8
Sideband
Sideband's Avatar
Yes I've come across these in a Philips radio. Mine only had three leads...the third being a screen. Usually found in places where hum pickup could be a problem. I replaced mine with a standard 0,01 but very carefully wrapped tinned copper wire around it for the length of the capacitor and then covered it with yellow heatshrink. Seemed to work fine.
Sideband is offline
