7th Oct 2019, 6:59 pm | #1 |
Roberts R606MB
Hi guys
I’ve been reading all of the useful information on here ref the vintage Roberts radios I am pleased to have a Roberts R606MB in tan which I’ve just picked up the first owners had it from new in mid 70s and it’s in very good condition with all brights and rexine and wood in not bad condition It works pretty well but a slight buzz when on the station but sounds great I was planning on following the advice on here to give it a full service and danish oil the end cheeks and rexine What do people recommend to clean rexine Is it normal for the tuning knob to press down whilst the volume is flush? Can the handle be tightened or is it loose in normal use Looking forward to being a member of this forum and restoring this Roberts to enjoy it Daniel |
7th Oct 2019, 7:26 pm | #2 |
Re: Roberts R606MB
I've got a R606 (not the MB version) here; I've also got a R24 (mains/battery) - the 606 I run off a homebrew mains supply [LM317 regulator) and it's hum-free.
The R24 was hummy on mains when I got it - problem turned out to be that the big smoothing electrolytic in the mains-supply had lost capacitance. A nice new 2200uF 25V electrolytic removed the hum - could be worth checking the smoother in yours? [remember that the main smoother is _always_ subjected to voltage as long as the radio's plugged into the mains - and when the radio's turned-off at the on-off-volume control the smoother will be unloaded and so charged to the peak-voltage of the AC waveform. Your smoother may have seen 100,000 hours of full voltage over a decade or so...!] |
7th Oct 2019, 8:18 pm | #3 |
Re: Roberts R606MB
If it hums on mains and not on batteries then #2 is almost certainly the explanation.
These radios contain lots of lovely Lockfit transistors which can be responsible for all sorts of strange symptoms. Search the forum for more stuff about Lockfits. |
8th Oct 2019, 2:02 pm | #4 |
Re: Roberts R606MB
Regarding the "Rexine" covering, it all depends on just how dirty it is. Use a medium toothbrush and detergent if just moderately marked. Or use "Cif" household cleaner (formerly "Jif") and a toothbrush if deeply stained/discolored. Be sure to rinse the white residue off.
Edward. |
8th Oct 2019, 8:11 pm | #5 |
Roberts R606MB stuck tuning scale pointer
Hi guys
I was attempting to remove the tuning knob as it appeared not to sit flush like the volume button, and the tuning scale pointer which was moving is now stuck off the left side of the display and will not move. It was working before, hope it’s not too hard to repair. Grateful for your advice Daniel |
9th Oct 2019, 9:40 pm | #6 |
Re: Roberts R606MB
Hi Daniel,
To remove the tuning knob, take a length of strong thin cord and wrap 2 turns onto the tuning shaft underneath the knob. If the chassis is still in the cabinet place your hand across the top to hold the radio down. Take 1 end of the cord to the left of the knob and the other to the right, grip them firmly and pull upwards. It could take a good pull to move the knob. Pull it slightly to the left and then to the right. It should come off. Dave. |
