14th Oct 2019, 2:50 pm | #1 |
Rank cintel 18920/1 6-30 volt transistor power supply
Would appreciate any information on this unit, It has been really got at, have managed to repair broken lifted print using turret mountings, it is not working so think there may be parts missing as well,circuit diagram would be great as it looks quite a neat unit as you can see both meters have been broken.
John |
14th Oct 2019, 6:34 pm | #2 |
Re: Rank cintel 18920/1 6-30 volt transistor power supply
John,
I have had one of these since my days at STC in 1977! Useful little power supply, mine was a non worker and managed to get hold of some info from MSL Calibration Centre, probably long since gone! If you pm me your email I could scan what I have for you. Alan |
14th Oct 2019, 7:30 pm | #3 | |
Dissolved in 2014 by the look of it but dormant for quite a while before that :- https://beta.companieshouse.gov.uk/company/SC058267
Chris Last edited by evingar; 14th Oct 2019 at 7:33 pm. Reason: additional info |
16th Oct 2019, 8:50 am | #4 | |
Have received all the information I need to refurbish the unit. Will now order replacement meters, will let you know the progress when complete. John ps Chris looked on the site as you say now defunked. John |
20th Oct 2019, 8:13 am | #5 |
Weren't MSL taken over by Trescal?
18th Jan 2020, 12:03 pm | #6 |
Just a follow up on this little power supply. all working as you can see,
a little fault on it is that you have to switch on higher range first for it to work on lower range,just a niggle not a problem once you know. john |
