Old 23rd Mar 2018, 11:48 am   #1
nigelr2000
nigelr2000's Avatar
Default QTX Power amplifier weird fault
Not all that vintage as it's dated 2010 but this repair has me a bit foxed. When powered it works fine on both channels but within 2 to 10 minutes both channels go hummy with no music protection relay stays in.
First impressions I found one of the main electrolytics cooked and forcing itself off the board so ordered new ones thinking it was the fault.
No such luck same fault so I measured the power lines negative at about -35 volts and the positive a massive +80 volts no wonder the 63 volt cap was getting annoyed.
I checked the AC in and that was normal both lines equal with the amplifier disconnected. Discharged the caps and fitted new rectifiers in the bridge in case one was playing up in some way. Powered it up with the amp disconnected and got - 46 and +54 on the board connections bit of a miss match but maybe the new eletrolytic had been damaged by the volts so plugged the amp back in and it worked.......for about 2 minutes then went hummy, checked the supply lines and I had the same imbalance.
I am very confused now, where on earth can it be getting the high volts from anyone got any bright ideas please.
ID:	159769   Click image for larger version
ID:	159770   Click image for larger version
nigelr2000 is offline
Old 23rd Mar 2018, 12:03 pm   #2
dave cox
dave cox's Avatar
Default Re: QTX Power amplifier weird fault
The PSU should be ~ 50-0-50. It looks like the transformer is supplying a center tap (GND, next to the 2 blue AC lines) so the 2 voltages should be quite close unless the GND / center tap is open circuit ...
dc
dave cox is offline
Old 23rd Mar 2018, 1:44 pm   #3
Welsh Anorak
Welsh Anorak's Avatar
I have had a similar fault on a different amp where the centre tap was intermittent causing all sorts of confusion. Check it as Dave suggests - also check any other earth points from the CT.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 23rd Mar 2018, 2:41 pm   #4
Refugee
Refugee's Avatar
The other thing that could cause that fault is if the amp has started oscillating so that the unwanted signal is getting rectified and added to one of the supply rails.
Small electrolytic capacitors are the worst of causing this kind of problem.
Refugee is offline
Old 23rd Mar 2018, 10:45 pm   #5
kevinaston1
The last three QTX amplifier faults I had were all dry joints, they seemed to be littered with them.
Do you have the circuit diagram for the QA400? If not, telephone AVSL in Manchester, they are always quite helpful, but you will need to quote them the six digit model code on the back panel (nnn.xxx); they do not recognise items by their model number.
Regards.
Kevin
kevinaston1 is offline
Old 25th Mar 2018, 12:07 am   #6
nigelr2000
nigelr2000's Avatar
Right got lots to look at on Monday morning when I am back in the workshop. Thanks everybody for the help, I will report back on my findings
Old 26th Mar 2018, 1:34 pm   #7
nigelr2000
nigelr2000's Avatar
Right thats that sorted, bit unusual it was a manufacturing fault on the power PCB where the track has a section damaged just on from where the pcb connects to the centre tap lug like a crack but the board wasn't cracked. After a quick rub over with a fibre pen I cleaned it up and bridged it with a solid wire now been running an hour without any problems.
That means welsh anorak was right about missing centre tap.
Kevinaston1 pointed me at looking at the boards carefully.
Thanks for the help people.
ID:	159967   Click image for larger version
Old 26th Mar 2018, 2:55 pm   #8
Radio Wrangler
Radio Wrangler's Avatar
PCB shops use a dry film photoresist. Bought on a roll, applied by rollers. If it creases, etchant can get into the little tunnel under the crease and thin the copper down. Either creating an open circuit track (or several) or else a weakened one that fails later.
Had to fix a new Roberts which went down with this problem just a few weeks old.
Radio Wrangler is online now
Old 26th Mar 2018, 10:23 pm   #9
Refugee
Refugee's Avatar
I can remember buying an AT motherboard to replace an older slower one that had been on fire. All boards except the graphics card had been destroyed by pulses from the arcing inside the fire.
The power supply was all right until I put the new motherboard in.
The top layer of the mask had been damaged so that the -12V rail was shorted.
The antiquated power supply blew up its 3 terminal regulator that supplied the -12V rail.
I took the board back to the shop and we checked the traders stock to find that they were all duff.
I fixed the power supply and used a different MB supplied as a replacement.
It was built like a tank and lasted years after all those expletives.
Refugee is offline
