7th Mar 2018, 4:19 pm | #1 |
Light Box from old monitor?
I want to make a photographic light box for slide copying, 150x100mm would be large enough. I had the thought that one could be made from an old LED monitor. It would have to be an LED type I believe since I want to run it from DC or highish frequency to eliminate strobing with the DSLR I intend to use which I may want to operate at varying shutter speeds. Has anyone tried this or have any ideas? Trevor |
7th Mar 2018, 5:28 pm | #2 |
Re: Light Box from old monitor?
Markus Fuller has done something similar, although you may find his video a bit simple: https://youtu.be/VvVN5kHHg0Y
7th Mar 2018, 8:41 pm | #3 |
When I made a negative/slide copying jig a few years ago I just used a sheet of flashed opal glass and a conventional GLS bulb. Proper flashed opal glass does provide prettywell absolutely uniform illumination, but is quite expensive. Fortunately the largest size of negative I contemplated needing was 4" x 5" so the cost was reasonable.
