Old 18th Feb 2020, 11:12 pm   #1
FERNSEH
FERNSEH's Avatar
Default One valve FM tuners.
An article in the 1999 March/April GFGF magazine describes the operation of single valve FM radio adaptors that were marketed in West Germany in the early fifties. These receivers employ a special quenching oscillator which operates at around 30Kc/s.
In the UK Osmor marketed the "Mini Magic" FM tuner. The valve used in this receiver was an ECC81. I don't have the circuit for this receiver but here is an explanation how the circuit works:
A brief explanation of the circuit will show a simple ECC81 (12AT7), one half functioning as a superhet local oscillator @ 22m/c above signal frequency V1b) and the other half (V1a) as a super-regenerative detector @ 22m/c with a quench frequency of 30m/c. Discrimination of the 22m/c FM/IF signal is aceived by it's conversion to A.M. on the side skirts of I.F. the of the response curve and subsequent detection.
DFWB.
ID:	199269   Click image for larger version
FERNSEH is offline
Old 18th Feb 2020, 11:33 pm   #2
dave_n_t
dave_n_t's Avatar
Default Re: One valve FM tuners.
I believe this is the Fremodyne circuit. A search will show up lots of references; I believe it was also one of G.A. French's(*) 'Suggested Circuits' in Radio Constructor.
dave
(*) a.k.a. J.R. Davies, of Smithy and dick fame.
Dave Teague
dave_n_t is offline
Old 18th Feb 2020, 11:51 pm   #3
FERNSEH
FERNSEH's Avatar
From the GFGF article, a 1935 circuit proposition employing the quench oscillator technique.
DFWB.
FERNSEH is offline
Old 19th Feb 2020, 8:07 am   #4
Ed_Dinning
Hi David, was there not a pulse counting design in PW or WW in the 60's that only used 1 valve ?
Ed
Ed_Dinning is offline
Old 19th Feb 2020, 10:08 am   #5
kalee20
It does sound like a Fremodyne, and the circuit is consistent with this.
I suspect the Fremodyne has few technical merits (one of them being that it won't splurge super-regen type RFI across the band of interest and spoil it for other people close by; instead it will wipe out the 22MHz band). But it might have been arguably sufficiently different from super-regen, that it could be used without infringing Armstrong's patents.
I've been playing with super-regen FM circuits, in collaboration with a talented youngster from another Forum, with good results!
kalee20 is offline
Old 19th Feb 2020, 11:21 am   #6
FERNSEH
FERNSEH's Avatar
dave
From the Radiomuseum, information about the Fremodyne FM tuner:
https://www.radiomuseum.org/forum/fr..._detector.html
Hi Ed, I seem to remember the circuit of the pulse counting FM receiver was in a Radio Constructor magazine.
DFWB.
FERNSEH is offline
Old 19th Feb 2020, 11:21 am   #7
crackle
Circuit in the Radio Museum.
https://www.radiomuseum.org/r/schaub...satz_ue52.html
mike
crackle is offline
Old 19th Feb 2020, 11:35 am   #8
boxdoctor
Re Ed Dinning's comment:
I built a pulse-counting type FM tuner in the early sixties.
I do remember that the I.F. was at a rather low requency (< 120 Khz) rather than c.a. 100 Mhz). It was my own design, based on several articles I had read on the topic, and used two I.F. stages using EF80s, and worked rather well, except for the lack of any A.F.C. Tony.
boxdoctor is offline
Old 19th Feb 2020, 11:58 am   #9
FERNSEH
FERNSEH's Avatar
From the American Radio History website, the November 1964 Radio Constructor magazine. On pages 253 to 256 construction details of an FM receiver which has a pulse counting detector:
https://www.americanradiohistory.com...RC-1964-11.pdf
The standard 10.7Mhz IF is converted down to 200Khz.
DFWB.
FERNSEH is offline
Old 19th Feb 2020, 1:02 pm   #10
FERNSEH
FERNSEH's Avatar
Circuit diagram of the Schaub UE52 FM tuner:
https://nvhrbiblio.nl/schema/Schaub_UE52.pdf
DFWB.
FERNSEH is offline
