Old 24th May 2010, 11:08 am   #101
dominicbeesley
dominicbeesley's Avatar
Default Re: Oh no - another V4!
Thanks Frank, I remember your homemade lopt...it's one of the things I keep meaning to give a try out when I next make a telly.
So, what to do?
Remove the perspex bit - this looks tricky but not impossible...
Will cooking this break it up like Chris's? I've been looking at the construction and don't know how you'd get a short to the core as the wires all look to be well away from it unless the core has been "turned" round when the pitch was soft?
I was also going to cook the linearity and width coils.
At what temperature does the wire enamel usually melt?
I'd like to start this afternoon if possible - while Stacey's not here to see me get the entire kitchen, bathroom, carpet, car and next door's cat covered in black pitch!
Any help...please! I'm now way out of my depth!
Dom
dominicbeesley is offline
Old 24th May 2010, 11:34 am   #102
oldticktock
Hi Dom,
I would wait for Trevor to pop up and advise, as he's specifically done the V4 LOPT heat treatment a few times, I would hate it to end the same way for you.
I still do not fully understand where mine went wrong, It was a total of 2x 2 hour sessions and the pitch on the LOPT never dripped off in great quantities it really only got a bit tacky and shiny, its all intact nothing missing. The width and linearity coils were also getting the heat as a by product of the heating, some of the wax paper dried and peeled off the width coil.
Im quite surprised to be honest considering I was using the least aggressive of the three options for heating.
Chris
oldticktock is offline
Old 24th May 2010, 2:05 pm   #103
murphyv310
murphyv310's Avatar
I am surprised you had problems! I have lost most of the pitch off one I did and it didn't distroy the trannie!
I would make sure that it IS the trannie first, the width and linearity coils could be the culprit you know.
I know you didn't want to disturb the lopt and left it in but in reality its better out of the set.
I still would remove ALL the external connections from the transformer execpt for the EHT lead and check each connection on the transformer to the transformer metalwork on ohms for shorts or leaks, If nothing look elsewhere.
OOOOP's posted this on the wrong V4 thread
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 24th May 2010, 2:53 pm   #104
dominicbeesley
Any advice for me Trevor? I've removed the LOPT and if no contrary advice in the next hour I'm going to remove the perspex top if possible and bake it!
Dom
Old 24th May 2010, 3:15 pm   #105
murphyv310
murphyv310's Avatar
At 75C it should be fine I did one at 100c and there was a little distortion, give it a little prod when up to 70c and make sure its not getting soft.
Cheers,
Trevor.
Old 24th May 2010, 4:34 pm   #106
dominicbeesley
Righto tis in the oven - Will give it until six o'clock with frequeny checks at 60 degrees the pitch is soft an all looks well!
Not sure which way up to stand it while it cooks...
Dom
Old 24th May 2010, 7:55 pm   #107
Heatercathodeshort
Heatercathodeshort's Avatar
You may as well bung a few spuds round it at the same time. Seems a pity to waste all that good oven heat on an old LOPT. J.
Heatercathodeshort is offline
Old 24th May 2010, 8:22 pm   #108
dominicbeesley
You might be kidding but I'm going to put in the rest of the roast beef, Yorkshire puds and spuds we had last night to warm up in a minute while the footballs on....
Dom
Old 24th May 2010, 10:39 pm   #109
dominicbeesley
Well it's had six hours and it's still bubbling!
The perspex has warped a little but still useable.
I'll leave it overnight and give it a few hours tomorrow morning.
On the downside it made my spuds taste a bit funny!
Dom
Old 24th May 2010, 10:43 pm   #110
Alistair D
Alistair D's Avatar
Who would have thought that an oven thermometer would become a piece of test equipment!!!.
Joking aside, does anyone know the temperature range of a domestic electric oven?
Al
Alistair D is offline
Old 24th May 2010, 11:41 pm   #111
FRANK.C
FRANK.C's Avatar
Hi Al
Temperature range of electric oven is usually 35C (as a keep warm function) to 250C.
Frank
FRANK.C is online now
Old 25th May 2010, 1:36 pm   #112
dominicbeesley
Well its now had nine hours at over 100degrees and it's still making a ticking noise when I take it out. Is it really still farting out steam?
What should I do? It's starting to look very lopsided now - the paxolin sides set at a funny angle and the perspex corona ring holders are quite bent?
Dom
Old 25th May 2010, 2:16 pm   #113
murphyv310
murphyv310's Avatar
Hi
Stop, I only gave mine about 2 to 3 hours, natural heat will do the rest, hope its all ok.
Check it against the readings on OTT's thread.
good luck
Cheers,
Trevor.
Old 25th May 2010, 6:00 pm   #114
dominicbeesley
To quote Roy Walker: "It's good! But it's not quite right!"
Wiring the LOPT back up was a good hour's worth of finger burning fun - switched on and after a bit of twiddling got an .....almost full width picture!
EHT is up a bit at just over 10kV (my AVO8 seems to have lost its magnetism so this is an estimate) had to reset all the centring magnets and the frame amplitude and linearity.
Focus is a tad sharper and doesn't need to be all the way over. But width is still quite low. I've got to go out now but will try and get measurements from the line drive area again. I really can't think what it will be now other than a problem with the scan coils...
Dom
Old 25th May 2010, 6:08 pm   #115
Heatercathodeshort
Yes Stop and leave it a while to settle. The incredible bubbling, smoke, melted tar, burnt fingers, smells, fumes and frustration when replacing a Pye V4 line output transformer has to be experienced to be believed. Definitely has a 'slaughter house' feeling about it..J.
Old 26th May 2010, 12:26 am   #116
dominicbeesley
Hee Hee, is fun though - unlike abatoir work...
Any ideas what to check next?
Dom
Old 26th May 2010, 8:46 am   #117
murphyv310
murphyv310's Avatar
Hi.
I've known the width and lin coils to have shorted turns, sometimes they look quite cooked! What does it do with the drive trimmer now?
Cheers,
Trevor.
Old 26th May 2010, 12:53 pm   #118
dominicbeesley
Thanks Trevor,
I didn't get a chance to turn the chassis over last night before I had to go out. Will retry all the drive bits tonight.
Is there a test I can do on the width and lin. controls? It would be good to just know what their resistance, or even better inductance was supposed to be! Is it worth measuring their Q?
The width coil was a mass of goo hard to tell whether it was fromt he enamel or the tape. I replaced the tape anyway as there was a risk of a short between the leadout wires.
Dom
Old 26th May 2010, 6:07 pm   #119
dominicbeesley
Hi Lads,
Had a spare twenty minutes so went down, resoldered the EHT lead and put the cage back on.
Twiddling the line drive trimmer C101 gave the following results...
All the way out as pictured below: bright with more EHT (had to readjust height controls) and sharp pictures and full width but wobbly verticals
Mid way: dimmer narrower picture - no sign of "kink", less wobbly verticals still a reasonable picture
All way in: very weak looking EHT line wouldn't lock, dim picture at about 3/5 width
No sign of any kink and these all tried with C99 subbed by a 100pF cap.
This all with width control turned fully up (i.e. iron core all the way in).
What to check next? Or should I just leave it!? I'd really like to get this running 100% though - including the width control near the middle!
How to check the width control coil or should I just rewind it!?
Dom
ID:	36340   Click image for larger version
Old 26th May 2010, 7:28 pm   #120
Steve_P
Steve_P's Avatar
Is the power supply OK at all levels. If not it could cause this sort of thing. C103 if not already changed.
Cheers,
Steve P.
Steve_P is offline
