6th Dec 2021, 10:56 am | #1 |
Avo multimeter model da116
Hello all, I have a digital AVO multimeter type DA116, unfortunately, one or two segments of the LCD display are missing. I have tried to contact AVO ( IF THEY STILL EXIST? ) without success. I am quite happy to dismantle the meter to see if there and markings on the display, ie ref number. Many thanks. George.
6th Dec 2021, 11:42 am | #2 | |
Re: Avo multimeter model da116
Technical support: 01304 502 102 |
6th Dec 2021, 1:13 pm | #3 |
O, thank you for that, I have tried to contact them without success, again thank you/
6th Dec 2021, 8:25 pm | #4 |
I don't know if it's similar to the display problems old Fluke DMMs develop, but have you checked if it's just a bad contact on the zebra strip between the LCD & the PCB? this might need cleaning or replacing if the strip can be obtained.
David |
8th Dec 2021, 8:59 pm | #5 |
Hello David, thank you for that, I have cleaned all the pins on the LCD display, however, without success. again thank you. George.
8th Dec 2021, 9:05 pm | #6 |
On another note I am building a RF power meter, there are two eight pin SM I/Cs one which is a LT1019, a 2.5 volt regulator I/C, however, there are no markings to indicate which is pin 1 ? no dot or cutaway on the chip ? anyone any ideas
