Old 5th Nov 2017, 12:09 pm   #1
RastaMan0
Default Radio PYE without model
Sorry for my english
Hello . Can you help me?
I have radio PYE but don't have identification him
can you help identifaciton him?
ID:	151840   Click image for larger version
ID:	151841   Click image for larger version
ID:	151842   Click image for larger version
ID:	151843   Click image for larger version
RastaMan0 is offline
Old 6th Nov 2017, 5:46 pm   #2
Default Re: Radio PYE without model
Hello and welcome to the forums.
Please post a picture showing the lower half of the tuning scale. This should show the intended market and indicate whether this is an export model.
What valves are fitted?
Station X is online now
Old 6th Nov 2017, 8:27 pm   #3
This is just guess work, the label on the chassis rear apron seems to read...clairton...
The antenna and earth socket on the left seems to be marked A and T?...Antenna and Terra? (aerial and earth)
The vertical white bits of trim look as though they have some embellishments on them.
I've not seen that style of IF transformer in a Pye before.
North Africa/Middle East/French market?
Old 15th Nov 2017, 10:47 pm   #4
RastaMan0
Tomorrow i make more photo. Thanks for help guys.
Yeah its Middle East you're right. Israel or Lebanon i am not sure but i buy this in Israel.
Old 19th Nov 2017, 1:08 pm   #5
RastaMan0
The interior of the Radio.
ID:	152500   Click image for larger version
ID:	152501   Click image for larger version
ID:	152502   Click image for larger version
ID:	152503   Click image for larger version
Old 19th Nov 2017, 6:37 pm   #6
RastaMan0
More photo. I think this radio was repaired before.
ID:	152539   Click image for larger version
ID:	152540   Click image for larger version
ID:	152541   Click image for larger version
Old 20th Nov 2017, 9:25 am   #7
Radio Tech
Radio Tech's Avatar
Very similar to the P75 model, but there may be a model number on the back panel or even on a label inside the wooden case. I would, when you do get the circuit diagram is to concentrate on those capacitors, most if not all will want renewing. Valve number one looks as if it has the vacuum broken as it is white at the top.
Good luck with it though, and welcome to the forum.
Best wishes
Ken
Radio Tech is offline
Old 20th Nov 2017, 9:32 am   #8
It's nothing like the P75.
Old 20th Nov 2017, 12:23 pm   #9
RastaMan0
Yeah i am sure its not P75
Box photo
ID:	152562   Click image for larger version
ID:	152563   Click image for larger version
Old 20th Nov 2017, 12:34 pm   #10
Full pics of the chassis, including a front view?
And close up pic of the "CLAIRTON" label?
Old 20th Nov 2017, 12:36 pm   #11
RastaMan0
I'm curious to know what kind of model it is, and after that, I already have to repair it. A transformer is located on it. Lawrence spoke correctly, this is an export model, is there a catalog of export models?
Old 20th Nov 2017, 12:38 pm   #12
RastaMan0
Give photo what is chassis in Radio. i cant unds what is it
Thanks.
Old 20th Nov 2017, 12:40 pm   #13
Why do you think this is a Pye radio?
What valves/tubes are fitted?
Old 20th Nov 2017, 12:45 pm   #14
Remove the radio from the cabinet and take photo's of the radio (not the cabinet) we need full views showing all of the front, top, rear and underneath, also a close up photo of the "CLAIRTON" label on the rear of the radio that's shown here on the bottom right hand side of the rear of the chassis:
http://www.vintage-radio.net/forum/a...3&d=1509879187
Old 20th Nov 2017, 12:48 pm   #15
These are two of the pictures needed.
ID:	152566   Click image for larger version
Old 20th Nov 2017, 12:50 pm   #16
RastaMan0
Because when I first took this radio, I saw this inscription PYE Cambridge)
Old 20th Nov 2017, 1:02 pm   #17
I've done a lot of searching on the internet for clues, not a lot that's conclusive to be honest, the only thing that looks Pye about that receiver is the tuning scale and possibly the cabinet.
The Belton capacitor hasn't turned up much either except for an old print on Google images referring to a company called Belton AG of Zurich that had something to do with radios:
http://www.walter-antiquariat.de/Bel...tising-Kolumbu
And a photo on vintage French radio site showing an identical capacitor (condensateur) to the one in the OP's receiver:
http://tsf.resto.free.fr/astuces/CON...densateurs.htm
Old 20th Nov 2017, 1:03 pm   #18
RastaMan0
Okey . i finished
ID:	152568   Click image for larger version
ID:	152569   Click image for larger version
ID:	152570   Click image for larger version
ID:	152571   Click image for larger version
Old 20th Nov 2017, 1:08 pm   #19
RastaMan0
I think this is such a strange device, because its speaker is very old (the company that produced it existed from 1936 to 1948) . I have 1 more radio) have name and number but googlo dont know what is it. But its not pye its Sert.
Old 20th Nov 2017, 1:09 pm   #20
Ages ago when the thread first started me and my wife were trying to figure out the word shown under CLAIRTON in the original photo, we both went for Paris
Seem to remember at that time I did a Google search for Clairton of Paris but couldn't find anything.
Anyways, back to the plot.
