Old 22nd Aug 2017, 5:28 pm   #1
FERNSEH
FERNSEH's Avatar
Default Columbia Table Radiogram.
This neat Columbia table radiogram is OK except that the record deck doesn't slide in and out with any precision. To improve matters the owner has supplied me with a pair of metal draw runners which should solve the problem.
About the Columbia radiogram. I suspect it was made by Sobell under a special agreement with EMI in which there was an exchange of share capital between the two companies in order to facilitate a deal with GUS stores.
The cabinet doesn't have that EMI look about it.
DFWB.
ID:	148234   Click image for larger version
FERNSEH is offline
Old 22nd Aug 2017, 10:26 pm   #2
Stuart R
Stuart R's Avatar
Default Re: Columbia Table Radiogram.
Hello,
A few of these have cropped up here before. I know you haven't asked for ID, but if the back's missing and you have no model number to go by, it's a Columbia C401.
The original wooden runners aren't much good, not helped when the milboard underneath sags.
Regards,
SR
Stuart R is offline
Old 24th Aug 2017, 5:14 pm   #3
FERNSEH
FERNSEH's Avatar
SR wrote: "it's a Columbia C401." Indeed it is and there was Marconi branded table radio that employed a similar chassis, the T32A.
http://www.radiomuseum.org/r/marconi_t32at_32.html
Job done. The new metal draw runners work perfectly, much better than the original arrangement with wooden runners.
The gram draw front has been given a rub over with French polish.
The electrical restoration work on the chassis will be carried out by another Forum member.
DFWB.
ID:	148336   Click image for larger version
FERNSEH is offline
Old 24th Aug 2017, 7:19 pm   #4
wd40addict
wd40addict's Avatar
Where's the speaker grille?
wd40addict is online now
Old 24th Aug 2017, 10:34 pm   #5
FERNSEH
FERNSEH's Avatar
The Columbia table radiogram has a loudspeaker aperture at both sides. If one thinks about it with the addition of a second amplifier a compact stereogram can be created from this unit.
DFWB.
FERNSEH is offline
Old 24th Aug 2017, 11:15 pm   #6
Stuart R
Stuart R's Avatar
A nice job with the runners.
I hadn't considered any Sobell relationship, but a quick search found the Sobell 553W radio, which looks very similar with a gold metal grille and simple cabinet.
http://www.radiomuseum.org/r/sobell_553w.html
My Image search then found an image of the Rolland 445 radio on Radio Museum which has a very similar dial and layout - never heard of one of those, was that another catalogue brand?
http://www.radiomuseum.org/r/rolland_unknown.html
Regards,
SR
Stuart R is offline
Old 25th Aug 2017, 12:50 am   #7
FERNSEH
FERNSEH's Avatar
More info about Rolland and Sobell:
http://www.radiomuseum.co.uk/land.html
DFWB.
FERNSEH is offline
Old 25th Aug 2017, 8:52 pm   #8
Stuart R
Stuart R's Avatar
Thanks for posting that link, an interesting read which then links to a restoration write-up of a Rolland radio.
SR
Stuart R is offline
