24th Aug 2019, 5:08 pm | #1 |
Panasonic NV-HV60 VCR
I bought this machine new about 15 years ago and had been using it on a regular basis until one day, it went dead with a cassette stuck in it.
This afternoon, I decided to take a look at it; alas, it was not going to be straightforward as I do not have a service manual for this model. I spotted a 1000mfd/10-volt capacitor in the power supply that had a distinct bulge in its can so decided to replace it. I then discovered that in order to remove the printed circuit board, I first needed to remove the stuck cassette as two of the screws securing the board were beneath the deck. Anyway, I replaced the offending capacitor but the machine is still dead. The display is not illuminated and there is no response from any of the controls. So - is there anyone out there who can offer any suggestions? Many thanks in anticipation. |
25th Aug 2019, 2:23 am | #2 |
Re: Panasonic NV-HV60 VCR
Did you look for blown fuses in the PSU? Do you have an ESR meter to measure the caps?
25th Aug 2019, 9:17 am | #3 |
The mains fuse is intact. Power is getting as far as the 33mfd smoothing capacitor, which has tested ok. The fault appears to be somewhere in the SMPS. However, as I do not have a circuit diagram I am now a bit stuck. I was hoping that someone may have some experience of this model and its stock faults.
25th Aug 2019, 9:56 am | #4 |
25th Aug 2019, 1:03 pm | #5 |
A possibility would be an open circuit startup resistor. This is a very common fault with switch mode power supplies in all sorts of equipment. There is a thread that mentions this problem in a Panasonic VCR here
https://www.vintage-radio.net/forum/...d.php?t=158211 John |
25th Aug 2019, 7:35 pm | #6 |
hi, most panasonic vcr,s have a 1uf 63v in the primary of the smps which dries up we used to replace these with 1uf 100v 105degree types
25th Aug 2019, 7:52 pm | #7 |
Check R1150 and R1154 both 1 meg resistors, these are the two start up resistors for this machine, one or other usually goes either O/C or high resistance.
I don't suffer from Insanity. I enjoy every minute of it. |
