Old 16th Jun 2009, 12:04 pm   #1
DoctorWho
DoctorWho's Avatar
Default Which Aurora do I need?
Thanks to Trevor I am now about to be the proud owner of two 819-line TV sets:
https://www.vintage-radio.net/forum/...296#post252296
I'd very much like to use these, but I see that there is more than one 819-line Aurora available, and I don't want to get the wrong one, so any advice here appreciated.
Also, does anyone know where I can obtain service data for these sets please?
Thanks for any help.
Peter.
DoctorWho is offline
Old 16th Jun 2009, 2:27 pm   #2
Boom
Default Re: Which Aurora do I need?
Personally if I had the spare cash I would go for the all in one Aurora Peter. You never know what's around the corner.
The exchange rate has picked up too.
Boom is offline
Old 17th Jun 2009, 11:13 am   #3
murphyv310
murphyv310's Avatar
Hi Peter.
David is correct about the World converter if you can afford it!
I have the full diagram for the Philips which I will send with the set, so far a blank on the Sonneclair though but I am sure our French friend will help here. There's no sound on the Sonneclair but its n o/c HT feed to the ECL86 so it needss to be done plus possibly the valve as well I've no time to do it though but an easy fix for you, its a really good set to work on.
Trevor
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 17th Jun 2009, 12:11 pm   #4
DoctorWho
DoctorWho's Avatar
David - The cost is a problem too, but I also think that the world converter has modulator, is that right?
Which of the 819-line modulators do I actually need from Darryl's site please?
Tervor - Thanks, unfortunately I can't afford the world converter, but also I believe that has no modulator in it? Which of the 819-line modulators from Darryl's list is the right one for these sets? Many thanks for sending the circuit diagram, that will be very helpful. It shouldn't be too hard to locate the O/C HT feed to the ECL86, I'll ask for some help on here if I get stuck. Looking forward to using the sets, thanks for letting me have them.
Old 17th Jun 2009, 12:26 pm   #5
DoctorWho
DoctorWho's Avatar
I just had a look at Drryl's website and these are the thhee 819-line converters available:
SCRF819E PAL(625) to 819/25i with RF System E modulator
SCRF819F PAL(625) to 819/25i with RF System F modulator
SCRF819L PAL(625) to 819/25i with RF System L modulator
Any advice as to which one I need here would be appreciated.
Many thanks,
Peter.
Old 17th Jun 2009, 12:37 pm   #6
ppppenguin
ppppenguin's Avatar
The world converter does have a modulator. You may be confusing it with the very first Aurora which had multiple standards but no modulator.
I don't know enough about the various 819 line systems to be able to say which version of the SCRF you should use.
ppppenguin is offline
Old 17th Jun 2009, 12:54 pm   #7
DoctorWho
DoctorWho's Avatar
Thanks Jeffrey, I was indeed confusing it with the first model, I didn't realise it had been updated.
I suspect the cost will make it prohibitive for me at present, so if anyone could advise me which of the 819-line converters I need I'd be grateful.
Peter.
Old 17th Jun 2009, 2:11 pm   #8
tubesrule
tubesrule's Avatar
Hi Peter,
It depends on where the set was destined to be used. System E was used in France and many French territories as was System L . System F was used primarily in Belgium. You need to determine which RF System the set uses. You might be able to figure this out from the schematic.
The World Converter does have a built in modulator with 30 different RF Systems and over 800 channels preprogrammed, plus the user can create their own custom RF System. (edit: I see Jeff already answered this one)
Darryl
tubesrule is offline
Old 17th Jun 2009, 2:13 pm   #9
murphyv310
murphyv310's Avatar
Hi Peter.
Both the sets were for the Paris 819 line service, I am unsure though what system that is. Ask Wiwor on this forum he will know the answer, I believe both sets came from him.
Regards
Trevor
Hi Darryl just pipped me to the post but it looks like System "E"
Cheers,
Trevor.
Old 17th Jun 2009, 3:31 pm   #10
tubesrule
tubesrule's Avatar
Originally Posted by murphyv310 View Post
Hi Peter.
Regards
Trevor
I would agree Trevor. If they were for Paris service than System E would in order. Still it wouldn't be a bad idea to check with Wiwor.
Darryl
Old 17th Jun 2009, 5:12 pm   #11
DoctorWho
DoctorWho's Avatar
Thanks for the input here, that's really helpful. It definitely looks like System E then.
Old 20th Jun 2009, 10:40 pm   #12
murphyv310
murphyv310's Avatar
Hi Peter
The TV's are slowly heading their way down south, I took them to Newcastle & Mikey405 now has them.
Trevor
Cheers,
Trevor.
Old 22nd Jun 2009, 6:04 pm   #13
DoctorWho
DoctorWho's Avatar
Thanks Trevor, that's really kind of you.
Now I shall be looking for some more 819 sets.........
Old 15th Jul 2009, 6:38 pm   #14
jimbo625
Hello Darryl,
Are you still producing the Aurora converter? I have a PAL/NTSC conversion requirement but need a capable but compact converter. Please let me know if
it is possible to order?
Thanks,
James
Last edited by Brian R Pateman; 15th Jul 2009 at 9:39 pm. Reason: E-mail address removed - please read forum rules.
jimbo625 is offline
Old 15th Jul 2009, 11:56 pm   #15
tubesrule
tubesrule's Avatar
I am still producing them, but don't want to go OT, so I'll send you an email.
Darryl
Last edited by Dave Moll; 17th Jul 2009 at 2:37 pm. Reason: quote of preceding post removed
