Old 4th Nov 2019, 7:26 pm   #1
zawoblondon
Default Vintage TV with RF modulator
I want to be able to see video from my DVD in an old TV (70's).
At this moment I'm connecting the composite video cables from the DVD into a RF modulator.
Then coaxial cable from the RF modulator to an UHF transformer.
And the UHF transformer is connected to the TV old TV antenna.
The RF modulator is set to work at the channel 50, so I set the TV to show that channel.
For that channel the video signal is just showing 2 shades of grey separated by a vertical line at the middle.
The setup is the same others are using to make it work, so I'm not sure if I'm doing anything wrong or it's just that the TV itself is not working anymore?
Any help is much appreciated.
I attach some photos of the hardware.
ID:	193108   Click image for larger version
ID:	193109   Click image for larger version
zawoblondon is offline
Old 5th Nov 2019, 2:20 am   #2
ben
ben's Avatar
Default Re: Vintage TV with RF modulator
Inter - that's a long disappeared Spanish brand name. Where did you get it? It is likely Pal -B/G, not Pal-I, as found in UK analogue equipment.
It could be that the output level is too high from the modulator, have you tried turning it down a little?
Post a picture of the back of the set with the connections so we can see exactly what goes where.
The TV could of course have a problem or misadjustment in the sync or tuner I suppose. Try adjusting the vertical or horizontal hold controls, usually on the back of the TV set.
Regards,
Ben.
ben is offline
Old 5th Nov 2019, 10:45 am   #3
simpsons
This modulator is quite clever and will provide sound for both UK and European model TV's. In addition, both video, audio and RF levels are adjustable. It has a test signal facility which is accessed via the unit menu. A YouTube video in Spanish explains how to set it up.
Given the problem is vision, l suggest this needs to be addressed first.
My first impression is that the TV is seeing an unmodulated video carrier. Your hook up seems right so first set the modulator to produce the internal test signal. See from the manual what is expected. If necessary use a second TV to confirm that the all is well. Make sure the test signal is then turned off.
Some DVD players, through the menu, expect the user to switch between RGB and composite should the Scart socket be use. Should it be set to RGB there will be no composite output. Check the setting.
The preset adjustments on the modulator should be adjust according to the instructions.
Chris
simpsons is offline
Old 5th Nov 2019, 3:57 pm   #4
julie_m
Do they? I have never known a DVD player like that.
The SCART wiring standard uses the composite video signal to provide the sync pulses in RGB mode, precisely to avoid this situation. If the set is unable to display an RGB picture, it falls back to displaying the picture from the composite video signal. And if there is any crosstalk, the "unwanted" information is being generated from the same RGB coming up the cable separately, and whatever is trying to break through will be the same as what the set should be displaying anyway.
Sometimes there is a menu item to select between RGB and S-VHS; the latter via SCART uses what would ordinarily be the "red" channel for the colour information and the "composite" video channel for a mono picture. A composite-only SCART input fed from an S-VHS source will still display a mono picture.
An RGB input would not be able to make any sense of such a signal; but the RGB switching line (on pin 16, if you ever have to disconnect it) would not be asserted with the output in S-VHS mode, so the set should fall back to displaying the picture encoded in the video signal.
At any rate, even connecting a DVD player in the "wrong" mode to a TV ought to give you enough of a picture to be able to see the on-screen menus and select the right mode.
julie_m is offline
Old 5th Nov 2019, 5:09 pm   #5
peter_scott
peter_scott's Avatar
The screen image looks like a possible test signal that the modulator generates to make tuning-in the television easier. I wonder if it generates this in the absence of a video input or whether there is a switch somewhere to select the source. Is the TV receiving sound signals from the modulator?
Peter
peter_scott is offline
Old 5th Nov 2019, 5:44 pm   #6
19Seventy7
19Seventy7's Avatar
Going off what Peter said, it's simple but might help
My modulator has a similar effect on screen when there isn't a proper input signal. I can get sound with a blank grey screen, or I can get video with no sound.
Could there be a loose connection somewhere internally or externally from the source or modulator itself?
19Seventy7 is offline
Old 5th Nov 2019, 6:38 pm   #7
zawoblondon
I have tried turning the output and video levels up and down. It only affects to the noise of the image, but the two shades of grey still appear.
The test signal is working. I can see two vertical white lines over a black background.
The TV makes some beep sound when the modulator is on test mode, but no sound on normal mode.
In normal mode (not test) the TV shows the same image whether the DVD is connected (and on) or not. The DVD works as I tested it in a different TV.
I attach an image of the test signal.
Old 5th Nov 2019, 8:18 pm   #8
simpsons
I notice that horizontal bars superimpose the test signal.
What happens when you plug the modulator into the other TV?
What is the make and model of your DVD player?
Also, notwithstanding Julie M comment, are you using an adaptor to connect the modulator to the scart socket or is there a composite output from the DVD player which you are connecting the modulator to?
simpsons is offline
