Old 16th May 2019, 2:16 pm   #1
Steve_P
Steve_P's Avatar
Default Brenell Mk5 Oscillator
Here is a funny one - The EL84 Oscillator had to be rebuilt as per the manual. The Erase Head reads OK on the meter. The Brenell coil was missing so I subbed a coil from another machine that also uses an EL84 oscillator, Everything else is as per the circuit. it does not oscillate,
Help.....
Steve P.
Steve_P is offline
Old 16th May 2019, 6:55 pm   #2
Chris55000
Default Re: Brenell Mk5 Oscillator
Hi!
Have you checked the anode/grid phasing?
The simpler bias oscillators use a simple single winding with a tap at an intermediate point for the h.t. supply connection, which normally ensures the correct phasing if the outer end of the winding is capacitor–coupled back to the grid, as is usually the case, but I think Brenell may use separate windings, in which there's always a possibility of mis–phasing, which results in failure to oscillate.
Is the coil you exchanged identical to the original one? If it's not, you might have to compare the two oscillator circuits carefully in case there's differences in the reaction–feedback coupling.
Another possibility is that the coil you fitted has a lower 'Q' than your old one, so it might be worth trying about 20V increase in the EL84's G2 voltage by adjusting the h.t. feed resistor! The negative G.B might also have been different between the two circuits, in which case you should use the.component values/connections corresponding to the machine your replacement coil came from!
Chris Williams
Chris Williams
Chris55000 is offline
Old 16th May 2019, 10:36 pm   #3
Steve_P
Steve_P's Avatar
Working now Chris. Thanks for your help. i turned round the coil. I did not think it mattered but obviously it does.
Thanks again!
Steve P,
Steve_P is offline
