Old 24th Jan 2020, 7:10 am   #1
Renato71
Default Avo mk2 valve tester
Hi, I have fixed an avo mk2. I have measured many valves, if they are with few amperes, type ecc83, everything seems to work. If I try valves that should produce a lot of amperes, el36 and El 34, it doesn't measure correctly, all the valves indicate few amps. In the repair I replaced all the diodes with BYT52M, the ea50 with a new one, the capacitors, some resistors. I added two diodes and a 100uf capacitor to the milliamperometer. When measuring without valve all voltages are correct, the digital tester on the back also indicates the correct current. Ideas? Thanks Renato, from Italy.
Renato71 is offline
Old 26th Jan 2020, 2:31 pm   #2
Renato71
Default Re: Avo mk2 valve tester
Resolved! I found the problem, it was a bad contact in the "CIRCUIT SELECTOR". Finally everything works.
Renato71 is offline
Old 27th Jan 2020, 8:45 am   #3
Kevin Hoyland
Hello.
I am pleased that you have worked it out. I have a mk2 and enjoy using it.
Regards
Kevin.
Kevin Hoyland is offline
