Old 14th Oct 2019, 2:50 pm   #1
jonnybear
jonnybear's Avatar
Default Rank cintel 18920/1 6-30 volt transistor power supply
Would appreciate any information on this unit, It has been really got at, have managed to repair broken lifted print using turret mountings, it is not working so think there may be parts missing as well,circuit diagram would be great as it looks quite a neat unit as you can see both meters have been broken.
John
ID:	191896   Click image for larger version
jonnybear is offline
Old 14th Oct 2019, 6:34 pm   #2
alanworland
alanworland's Avatar
Default Re: Rank cintel 18920/1 6-30 volt transistor power supply
John,
I have had one of these since my days at STC in 1977! Useful little power supply, mine was a non worker and managed to get hold of some info from MSL Calibration Centre, probably long since gone!
If you pm me your email I could scan what I have for you.
Alan
alanworland is offline
Old 14th Oct 2019, 7:30 pm   #3
evingar
evingar's Avatar
Originally Posted by alanworland View Post
John,
Alan
Dissolved in 2014 by the look of it but dormant for quite a while before that :-
https://beta.companieshouse.gov.uk/company/SC058267
Chris
evingar is offline
Old 16th Oct 2019, 8:50 am   #4
jonnybear
jonnybear's Avatar
John,
Alan
Many Thanks Alan you are a star.
Have received all the information I need to refurbish the unit. Will now order replacement meters, will let you know the progress when complete.
John
ps Chris looked on the site as you say now defunked.
John
Old 20th Oct 2019, 8:13 am   #5
wd40addict
wd40addict's Avatar
Weren't MSL taken over by Trescal?
wd40addict is offline
Old 18th Jan 2020, 12:03 pm   #6
jonnybear
jonnybear's Avatar
Just a follow up on this little power supply. all working as you can see,
a little fault on it is that you have to switch on higher range first for it to work on lower range,just a niggle not a problem once you know.
john
ID:	197313   Click image for larger version
