9th Mar 2013, 12:38 pm | #41 |
Re: Hacker AF117 best alternatives?
Hello,
Is it only AF*** that have this problem, are other types (e.g. AC***) immune from it? This is just so I can decide whether to get some spares in! Michael |
9th Mar 2013, 12:50 pm | #42 |
Yes, just the AF11x's that have the problem of tin whiskers growing.
Dave |
9th Mar 2013, 1:00 pm | #43 |
Sorry - that's sadly not the case. AC128s, etc, can get them. Much less common, for whatever reason, and of course, not noticed unless the device is on an earthed heatsink or two electrodes have been reached. They respond to the zapping treatment though.
Mark |
9th Mar 2013, 6:54 pm | #44 |
Hi
The OC170 and OC171 have the same case as the AF11x series so these are also prone to tin whisker growth. I think there is an OC169 as well, though I've not personally seen one in commercial equipment. Symon |
10th Mar 2013, 10:42 am | #45 | |
The capacitor charge may be depleted on the first connection by having to zap more than one whisker, turning the transistor round into different planes and tapping it in all directions may cause another wisker to momentarily short and be zapped, if the capacitor is already part discharged by this time then additional whiskers which momentarily short may not be zapped. Having a constant supply eliminates the problem with the capacitor discharging and not being effective if and when another whisker momentarily shorts. Just a theory, but that is the way I do it now, and it has worked for me, the turning round and tapping is just a bit of belt and braces to try and catch additional whiskers "about" to short. Mike |
10th Mar 2013, 11:23 am | #46 |
For what it's worth, I never try to 'cure' AF117s or similar, but always adopt a 'replace on sight' policy, using AF12x series devices, which I know are getting harder to obtain(and more expensive!)now
10th Mar 2013, 12:42 pm | #47 | |
The advantage of having the capacitor at the transistor is that it eliminates any losses in the connecting cables - a bit like why the ICE crowd often put large super-caps or a second battery in the boot next to the amplifiers. Perhaps it's only a theoretical advantage, but the capacitor leads also give me a convenient point to clip the croc-clips from the PSU leads. All the best, Mark |
10th Mar 2013, 12:43 pm | #48 | |
Mark |
11th Mar 2013, 12:13 am | #49 |
Hi Mark
OK understand now. Cheers mike |
