31st May 2008, 4:59 pm | #1 |
Bush TR82/97 and other repros.
Hi all, while browsing my local car boot sale this morning, i spotted a filthy old
bush tr82b & rushed in to rescue it On closer inspection, it turned out to be a modern copy! but before i put it down, the guy on the stall said "yours for a quid" so a pound changed hands. I noticed that the large tuning knob looked identical to the original, so it was worth getting just for that! When i got in i tried it only to find it works perfectly so i am not now going to break it up. After a good clean, i compared it with my original bush (see pics) but after removing the rear centre screw, the back won't come free it seems to be invisably fixed at either side towards the top of the set. does anybody know how to remove it? can this set run from batteries? As a point of interest, does anyone know of other sets that have had modern copies made? as i have 4 originals (1 mains/battery valve & 3 transistor sets) it is worth keeping as the saying goes "immitation is the sincerest form of flattery" Last edited by Darren-UK; 1st Jun 2008 at 9:28 am. Reason: Given more accurate title. |
1st Jun 2008, 1:26 am | #2 |
Re: Bush tr82b & son
The modern Bush copy you've picked up looks to be the TR82/97 model, well done for getting it so cheaply BTW . I've got one of the DAB versions, the TR82DAB, which I'm sure uses the same method for securing the rear cover.
After removing the centre screw you need to push the entire back up or down and it should then come off. Its not just held on by the screw but by some plastic hooks as well. Underneath is another plastic cover protecting the electronics and a battery compartment. My DAB set has an holder for 6 x C cells, your set will probably be the same. |
1st Jun 2008, 9:11 am | #3 |
Hi Mark,
We lampooned these repro jobs a few years ago and, for your benefit, I have temporarily reinstated this thread which we'd sent to the forum graveyard. It should provide at least some of the info you seek on the TR82/97 and other repros. |
1st Jun 2008, 11:43 am | #4 |
Re: Bush TR82/97 and other repros.
Thanks to Robert & Darren for your comments, i will have a go at removing the back from my repro.
I have now read the threads about the repro, while i agree with a lot of comments made, imho i think sound quality, although is not up to the original it still is'nt to bad & a lot better than most 'modern' sets i have come across. It has now found a place as my kitchen radio! On the subject of the tr82b i bought another this morning for £2!! the bottom of the back is damaged & the tuning knob bright is missing, but on applying power it crackled in to life, after a squirt of switch cleaner, it is now sounding good, yet another set to go into the restoration pile (along with 2 suitcase portables, a nice little stella transistor & a cute phillips bakelite set) which i also bought this morning Pictures of the set below, keep a look out for a success story shortly |
1st Jun 2008, 11:52 am | #5 |
Missing brights and damaged cabinets are a very common problem with these. At least the 82B uses OCxx transistors, so you won't have the AF11x nuisance to deal with.
If you need any help with the 82B or any of the other radios you've mentioned, be sure to post in the correct forum sections and with seperate threads for each make please . |
12th Jun 2008, 2:48 pm | #6 |
My sister, always on the look out for radios at boot sales, bought me a TR82/97, complete with original box & packaging, mains lead, instructions & certificate for £4.
One thing I did find strange, apart from the well documented 'faults' with this model is the letter U in the word BUSH. Is it meant to be the shape it is? It's more like a horseshoe shape than a straight side U ! See pics below: |
12th Jun 2008, 3:11 pm | #7 |
There must be a lot of these TR82/97s about! , I bought one for £1 at a bootsale last Saturday , and that has the same funny shaped "U", a standard feature I guess . The volume control knob had fallen off mine, the fixing screw had come undone and was stuck to the speaker magnet, but after a lot of dismantling including the drive cord I managed to get it all working again, sounds quite good but the originals were much better engineered......
Regards, Mick. |
12th Jun 2008, 3:33 pm | #8 |
Hi Mick,
I think the owners of these repros are realising that they're not all they are cracked up to be, hence the appearance of them at boot sales. I've dismantled the whole tuning assembly ready to improve it, also the large dial knob needs a bit of spacing as it rubs on the body. The 'wonky' U is probably deliberate...a way of the trade identifying them from the original one. Just found a picture on the web that also clearly shows the wonky U: |
12th Jun 2008, 4:02 pm | #9 |
My understanding about the wonky "U" is that the prototype for the TR82/97 was a TR82 at the Vintage Wireless Museum which happened to have a wonky "U". This was faithfully reproduced.
Quite possibly true. Or urban myth? |
12th Jun 2008, 9:38 pm | #10 | |
One 'woody' & one 'machine age' both are now working fine after attention with switchcleaner Wonder if they will be around in 50 years though Last edited by Darren-UK; 13th Jun 2008 at 12:34 am. Reason: Fixed quote. |
13th Jun 2008, 9:32 am | #11 |
Re: missing dial brights from TR82Bs - Igranic has 'tooled up' and made a few of these - I got 6 of them from him (and I noticed they were on sale at the B&B stall at NVCF) - PM him for details
Cheers Andy |
