4th Nov 2014, 11:53 am | #41 |
Re: Variable HT regulator circuit.
Even better. BTW the seller accepted an offer of $15, so all-in including postage it was less than £13.00!
4th Nov 2014, 2:21 pm | #42 |
Hope it does the job Nick, but at an OP power of 20-30mA / 9W ,you might it be severely constrained to what valves you can test.
Andy.
4th Nov 2014, 3:59 pm | #43 |
Andy, Nick's measuring small signal valves and a low power output valve, not line-output or transmitting valves. He'll be fine. If not, just one MOSFET has to be replaced - 2 mins work and a quid's outlay.
Al |
13th Nov 2014, 2:13 pm | #44 |
Back again. I'm assembling the bits to build one of these. Is there any need to have an AF choke/capacitor smoothing circuit following the rectifiers?
Jim |
13th Nov 2014, 4:56 pm | #45 |
Hi Jim, if you're talking about the circuit that was posted early in this thread, no, you don't need a choke, but you do need the big electrolytics shown.
Al |
13th Nov 2014, 5:59 pm | #46 |
Hi Al,
This is the circuit I eventually ended up with, Jim |
13th Nov 2014, 6:17 pm | #47 |
Good result, I would have it variable down to zero (you never know, a ten turn pot is good here) and put a switch and a fuse (FETs go short on failure) on the output (after the meters). I was going to mention an output bleed but the volt meter will do that, talking of meters, a protection diode across the ammeter is a good idea. I like the gate series and protection too, well thought out and simple as all good designs are.
13th Nov 2014, 8:29 pm | #48 |
Cheers Merlin,
I do intend adding a fuse but hadn't thought of the diode across the meter. The LED and its resistor will bleed the 220uF capacitor. I'm thinking I might publish this* as I'm sure there are others out there who would like to build one. Jim *With due acknowledgements to the Forum of course! |
13th Nov 2014, 8:38 pm | #49 | |
One thing I like to use on high voltage stuff is a neon (even inside), very reliable. Rather guiding the lilly in this case though. |
13th Nov 2014, 9:47 pm | #50 |
Yes, I realised you meant the output Merlin and I'll do that as well I think. I considered using a Neon indicator too as even taking just 5mA extra from the transformer for the LED is quite a big percentage of the 100mA available with the transformer I'm using and Neons take less than that.
14th Nov 2014, 12:43 am | #51 |
Could you replace the string of Zenners with small wire-ended neons (with shunt resistors to help striking...)
Stuart |
14th Nov 2014, 8:46 am | #52 |
Rather than put the LED, and its series resistor, across the supply put it in series with R1. You'll still get 5mA through the LED and save a resistor and get an extra 5mA available at the output.
Keith |
14th Nov 2014, 1:35 pm | #53 |
14th Nov 2014, 1:36 pm | #54 |
14th Nov 2014, 3:04 pm | #55 | |
14th Nov 2014, 11:26 pm | #56 |
Nice one Jim.
This may just be the icing on the cake, but that Mosfet can source a lot of current..would it be an idea to add some simple crowbar s/c protection?
Al |
14th Nov 2014, 11:35 pm | #57 |
Yes Al, I've been mulling that over. I'll see what I can come up with tomorrow.
15th Nov 2014, 1:27 am | #58 |
I know that this has been devised as a VV supply, but would it also be a good way of dealing with limiting the very high off-load HT voltage which occurs during the period when a valve receiver is warming up? If the power supply uses silicon diodes, the HT volts can be surprisingly high - and close to the limits on various caps - prior to the time when the valves start conducting. Usually, I've used some crude combination of resistors/zeners/neons to keep things under some degree of control, but these can be a drain on the current available when the valves are on.
B
15th Nov 2014, 3:39 am | #59 | |
My sketch is a bit rough but I didn't tag the original circuit. Cheers
Al |
15th Nov 2014, 1:41 pm | #60 |
Nice one Al. I remember my boss having problems with the electrics on his boat many years ago. The solution there was to have a built in delay so I designed and built a unit based on a 555 which solved the problem for him. I never got a trip on his boat though!
