Old 14th May 2012, 11:40 am   #1
Ricardo
Default Labgear CM 6052/CB PAL Colour Bar Generator
I bought a Labgear CM 6052/CB PAL Colour Bar Generator at the NVCF yesterday. It has a switchable UHF/VHF output and is working well on UHF. At present I don't have any means of checking its output on VHF.
Anyway I have a question regarding the outputs that it provides. The main RF output connection is via a flying lead from the rear of the unit with a coax plug on the end. However there is also a coaxial socket on the rear of the unit.
Does anyone know what signal this second output provides and how it is intended to be used?
Any additional information about these units would also be appreciated.
Thanks and regards,
Richard
Ricardo is offline
Old 14th May 2012, 12:28 pm   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: Labgear CM 6052/CB PAL Colour Bar Generator
It could be a RF output or even a Aerial Input prior to feeding into an amplifier for workshop use around a number of service benches.
HamishBoxer is offline
Old 14th May 2012, 9:14 pm   #3
Marconi_MPT4
Marconi_MPT4's Avatar
Hi Richard,
On these colour bar generators, the extra socket is for directly triggering an oscilloscope. Both horizontal and vertical signals are available and are of sufficient amplitude to obtain a satisfactory trigger with most gear.
I have a service manual for this model scanned from a photocopy received from Pye Unicam some 30 years ago, but it is too large to post here. PM me if you would like a copy.
Rich
To an optimist a glass is half full; a pessimist half empty; an engineer twice as big as need be!
Marconi_MPT4 is offline
Old 15th May 2012, 7:03 pm   #4
Ricardo
David,
Thanks for speculating about how the extra output on the colour bar generator might be used, but Rich has subsequently given us a more definitive answer.
Rich,
I have looked at the output from the extra socket on my oscilloscope and it certainly appears to be sync pulses only. The vertical pulses have an amplitude of about 5 volts and the horizontal ones much less, but as you say enough to act as a trigger signal.
I would very much like to have a copy of the service manual and will send you a PM.
Thanks and best regards,
Richard
Ricardo is offline
Old 1st Jul 2016, 8:30 am   #5
Reginald
Hello Rich
I live in Western Australia and recently bought a CM 6052 CB generator at a club auction (VWGC.org.au). Although Australia no longer has analogue transmission I have several vintage TVs in my collection.
The unit is working well and just needed a bit of lube on the switches and the level pot.
Would it be possible to get a copy of the manual to keep with the unit please?
Reg Gauci
Western Australia
Reginald is offline
Old 1st Jul 2016, 3:01 pm   #6
Marconi_MPT4
Hi Reg, PM sent.
Rich
