6th Jan 2021, 10:01 pm | #1 |
Transformer calculations app
I’ve dusted off my (limited) coding hat to make a new version of an old simple transformer designer program by Silvio Klaic circa 1999.
Input is the EI tongue width, stack height and the mains voltage/frequency. Then add the desired secondary voltage and mA. Today I did the core design and winding turns calc, will add the wire gauges tomorrow. Anyone want to check I’m not making any major mistakes/add suggestions? To calculate the core power limit I used: Power in Watts = (core area in square cm / 1.152) squared To calculate the turns per volt: Turns/volt = 1/(0.000444 x mains freq in Hz x Flux Density in Wb/m2 x core area in cm) Primary winding current: Primary current in Amps = (Secondary V x Sec I) / (Primary V x Efficiency factor) Primary winding turns number = Turns/Volt x mains primary V Secondary winding turns number= Turns/Volt x Secondary V (optional loading factor can be added here) For the wire gauge, this will be used: Wire diameter = 1.128 x sir root (Current/Current Density in amps/sq mm. Standard density for copper = 3.5A/sq mm. I've added some screen shots of the original and macOS / Windows10 versions of the new one. Doug |
6th Jan 2021, 10:36 pm | #2 |
Re: Transformer calculations app
I have never seen the origional program!! It looks like a very nice piece of software!! I do hope you will compile a Unix/Linux version if you dont release your coding under a free licence.
EXCELLENT work. As far as correcting your math, I learnt my transformers in inches and lines/sq inch so I cannot help there. All the best for now Joe |
6th Jan 2021, 11:05 pm | #3 | |
In doing some reading, there's lots of info out there (RCA manual). I was brought up on feet/inches/pounds/oz but having worked in research labs SI units lust work better. I usually run the original program with Wine, works well but there isn't an option to set the laminations type. Good news for a linux and a web app version, I just need to add a single check to an option when building It's a niche app for me to wind a few tranformers and free to anyone who wants it. Doug |
7th Jan 2021, 12:11 am | #4 | |
Doug |
7th Jan 2021, 12:33 am | #5 |
I've hand wound transformers over the years but that was when you found more of them that were 'un-dipped' and could be disassembled easily. Getting hold of decent quality EI lamination's seems impossible these days.
That program would be very useful if you could post a copy? The original designer has taken his down due to wanting to update it but, as of 2005 there hasn't been one! |
7th Jan 2021, 1:18 am | #6 |
kellys_eye
Laminations that I use are freely available from India, and are a good price. The quality is excellent!! I used John Sankey ( a part of BHP before Billington took over) iron for many years, but like all other manufacturing in Australia, they closed some years ago. Buying iron is still a bit of a problem from the point of view of the vendors as they want to sell in large quantities. Even John Sankey would not do less that 25 kgs of a single type. Although it wont match "old radios/stereos", I would recommend 5% silicon Grain oriented steel. AKA 5%SiGO. because it can run quite high flux densities in the case of slight miss design, and in the case of output transformers distortion is lower and frequency response is better simply because the leakage is somewhat less if basic design rules are followed i.e. sectioning even to a small degree. I am watching this thread with great interest Joe |
7th Jan 2021, 9:31 am | #7 |
I've never wound a transformer, but it's something I have been thinking about for some time. This looks like a very useful app!
Martin BVWS member GQRP Club |
7th Jan 2021, 10:29 am | #8 | |
Doug |
7th Jan 2021, 10:54 am | #9 |
Hi Doug.
Congrats on the app Dougie, it looks great. I was just about to ask a question on this forum about this very thing, as I am toying with the idea of re-winding an Oscilloscope power transformer, and that would be just the thing. Funny how these things happen innit? I would like to take you up on your kind offer. Please may I have a copy/ link or whatever. ( for Windows) Thanks
7th Jan 2021, 11:56 am | #10 | |
My 1st one is a rewind of a 24V 1200mA mains adaptor/wall-wort to use in a 2W pp amp using EF80's... I'm still in the planning stage so I was thinking about the number of secondaries, I've only added scope for 2 so far but will add scope for more. More features to be added, eg a save feature to store settings, some EI templates for cold rolled grain orientated (and non grain orientated) laminates, this would allow for tongue width and flux density settings to be filled in. I need to tidy up the number formatting (too many decimal places) and turns need to be rounded up to whole numbers. Needs a sanity check on the total current rating of the secondaries vs the max power capacity of the core... Should have most done this week. Doug |
7th Jan 2021, 12:46 pm | #11 |
Sounds fabulous!
Will it be able to work out if the desired number of turns of users chosen size of wire would actually fit selected core/widow size? I’m thinking of winding a 240 to 950 which then gets “ doubled” to produce EHT for an Oscilloscope. It doesn’t need to be very big, as the current requirements are very little, but a high number of turns will be required for the secondary. This means ridiculously thin wire will have to be used in order that it all fits in the space available. I presume the varnish insulation will also be thinner, not ideal for such a large voltage. I’ll try a bigger version first, to see if I can run up the scope( I can produce the other voltages required) just to make sure all my efforts won’t be wasted.
7th Jan 2021, 1:14 pm | #12 |
Fitting the wire into the space...that's the skill part!
So far I've wound 2 small EI transformers, actually, I've only wound the secondaries! I took apart the laminations (wasn't too hard) The bobbins were the 2 part plastic types inside a sort of plastic holder that also isolates the primary from the secondary. I left the primary as is, the power rating was known as per the spec. I unwound the secondary (best not to use this wire for another wind but you can use it to try honing your winding technique). I wound a multi-tap secondary with 1st tap at 840 turns (for 120v), then 2nd tap at 1008 turns (144v), 3rd at 1176 turns (168v), 4th at 1260 turns (180v), 5th at 1344 turns (192v), 6th at 1512 turns (216v), 7th and last tap at 1680 turns (240v). The wire was 0.14mm, quite thin but still able to get a good tension (more tension = better winding density). Doug |
7th Jan 2021, 1:41 pm | #13 |
Hi Dougie.
Yes, it’s probably better to use a “ known” primary as that bit( the bit that scares me) is done for you. I have a couple of mains transformers I can re-purpose and also a number of old telecoms transformers and inductors ( all E-I)I would like to re use. I get the core size and volts per turn business, but the bit that bothers me is will resistance/inductance of my newly wound primary be right or will I just produce a smoke generator! Ready made primaries are presumably good from safety/regs point of view too.
7th Jan 2021, 1:51 pm | #14 |
Dougie. Let me know how you get on with that hand winder, as I might get one too.
7th Jan 2021, 3:21 pm | #15 | |
My DIY winder is an old 12v NiCd (battery long dead) electric drill motor and chuck mounted in a wooden frame, a 10mm threaded bar with nuts and large washers to hold the bobbin. Powered by an old 12v ATX PSU, for the counter I rigged up a 3 digit tape counter with a bodge job to get 1:1 turns/counter digit. See pics below, also shows free (gumtree) laminates from a microwave oven, 32mm tongue x 80mm stack and 3.3kg, should be good for 850W Doug |
7th Jan 2021, 6:06 pm | #16 | |
7th Jan 2021, 7:08 pm | #17 | ||
I' thinking it's a way to get real world estimates of efficiency losses from an ideal transformer. I'd rather get some real world core material differences built into my app, the old app I was using doesn't have any setting to change the core material, eg cold rolled grain oriented vs no grain oriented Core plate material__________flux density [Wb/m2]_____Core efficiency Grain-oriented silicon steel______1.2_________________ 0.84 Non grain-oriented silicon steel___1.1_________________0.82 I think this page might be better to use for the calculations:https://www.giangrandi.org/electroni...tml#core_table I need you guys to help to get it right, make suggestions for features etc. Doug |
7th Jan 2021, 10:39 pm | #18 |
Here is another way to calculate the recommended max power available from the core.
power = (efficiency x (square of the core area in mm))/14000 efficiency examples are CRGO=0.84 and CRNGO=0.82 When calculating the turns/volt the flux densities are CRGO=1.2 and CRNGO=1.0 Does this look better? |
8th Jan 2021, 7:24 pm | #19 |
Got the app looking a bit better, added space for 6 secondaries and some buttons with preset settings to load.
I'll try a transformer build next week once my new winder arrives and compare theory to real world. Doug. |
9th Jan 2021, 11:05 am | #20 |
My understanding is that the power handling capability of a transformer is not about the core itself at all. The core just determines your best turns/volt.
You then have to consider how much space there is for the windings - and the core affects it a bit but only in as much as the turns have to go round the core thus affecting the length and hence resistance of the winding. The key factor is the space you have available for the windings because the more space there is the thicker the wire can be and that very directly affects the power handling. Any formula just using the core area must be making a massive load of assumptions about the shape and dimensions of typical cores. BTW why do an "app" with all the attendant concerns when this stuff is easily calculated in a web page? And Google seems to find quite a few already. |
