Old 25th Nov 2020, 10:23 pm   #1
Chittaway
Default Pioneer SA 520 display woes
Hi all,
I'm new to to this forum and hope somebody can help me out,
I have a Pioneer SA 520 amp, all works fine except for the display panel which involves speaker meters and connected items, (buttons work ok), it all worked fine before I put it away some 4 years ago.
Any advice or assistance would be greatly appreciated as my OCD says they should work
Mick
Chittaway is offline
Old 26th Nov 2020, 7:13 am   #2
Diabolical Artificer
Diabolical Artificer's Avatar
Default Re: Pioneer SA 520 display woes
First check for loose connectors, check switches are working correctly if there's nothing obvious then get a manual or schematic, this will hopefully help track the issue down.
Andy.
Old 26th Nov 2020, 8:45 am   #3
trsomian
It appears to have a fluorescent display, so it may be that the supply to the display itself has failed. It seems to have a small transformer for this, so I would check the voltages around it, and, of course, don't forget to have a meter that will read AC rather than DC. The circuit diagram is available on HiFi Engine
trsomian is offline
Old 27th Nov 2020, 9:59 pm   #4
Chittaway
Thanks Diabolical Artificer,
all switches work ok, connections are tight, another reply suggests transformer for the display
Thanks trsomian
will definitely check it out I figured it could be transformer, haven't stripped it right down yet will do and check for possible dry loints
Mick
