21st Nov 2020, 7:06 pm | #1 |
Coomber record player running slow
I have a Coomber record player from the 70s/80s I guess. I've replaced the stylus and changed the drive belt, but it is running slow. I don't think the drive belt is slipping. Any advice? |
22nd Nov 2020, 7:38 am | #2 |
Re: Coomber record player running slow
may need to lube the motor any pictures as chancers are Coomber did not make the deck themselfs pics may help us ID it
22nd Nov 2020, 2:30 pm | #3 |
Thanks,
How do I lube the motor? Do I need special oil? It looks like it is a BSR turntable. Sorry about the quality of the pictures. Would it help if I wrote down the numbers on the labels on the motor / deck? |
22nd Nov 2020, 5:42 pm | #4 |
This is a late model BSR single player from the 1070s. I've only ever seen it in a Coomber and some disco twin decks. It's nowhere near as good as it might look!
Edward. |
22nd Nov 2020, 6:00 pm | #5 |
all the info off the red label or a clearer picture please as its a 12v motor check its getting 12v power looks like a P275 deck
22nd Nov 2020, 6:25 pm | #6 |
Look at the underside near the speed selector. Separate the metal chassis from the wood. There may be a potentiometer there.
Regards, Ben. |
25th Nov 2020, 8:52 pm | #7 |
Thanks, I'll take it apart this weekend.
The red label says: BSR P246 E3 PG6039/687 but the 687 has been crossed out and 535 written in pen 59 C L4 12 volts REF No. A105 Any use? |
26th Nov 2020, 8:29 am | #8 |
yes its a BSR P246 google should give you links to a service sheet not one i have
27th Nov 2020, 8:23 pm | #9 |
I've found the 33 & 45 speed adjusters and they worked, but when I move the speed selector the speed changes wildly. I'm guessing that the contacts on the selector switch need cleaning? If so, can you tell me how to clean them.
28th Nov 2020, 11:06 am | #10 |
The adjustment may be very sensitive, a 1/4 of a turn can make a big difference. Use Servisol 10 for cleaning.
Edward. |
