13th Dec 2009, 12:08 am | #21 |
Re: Double triode solid-state equivalent
I prefer to think of these "Holes" as States rather than an entity, but if you subscribe to the simplified Bohr model of the atom then I can see how they may be perceived as such.
I guess my point is as I touched upon with the cathode injection and the use of hexodes and heptodes for Mixers (except in the case of some VHF tuners where an ecc85 or the likes is used) is why isn`t this method proposed above used in all comercial sets, surely using a double triode would be a load cheaper than multigrid valves? from a pragmatic perspective it makes sense. |
13th Dec 2009, 12:07 pm | #22 | ||
Mike |
13th Dec 2009, 5:45 pm | #23 | |
Now take the two input signals to be a and b. Each valve gets one of these on its grid, and the other on the cathode. So the first valve has -ab, and the second one has -ba, but these are equal so we get -2ab. Alternatively, say the first valve has (a-b)^2, and the second has (b-a)^2 and multiply out. The result is the same. Basically what is happening is that we have a product of two factors and swapping the sign of either of them changes the sign of the product; we have one of each so they both have a change of sign. I think mathematically so I can't explain it without using algebra! |
13th Dec 2009, 5:59 pm | #24 | |
I think the double triode mixer is not used much because it has low gain (due to feedback from the cathode resistor), and poor isolation between the inputs and output. This could cause oscillator pulling and oscillator radiation in a broadcast receiver, as these typically have no RF stage and no buffer after the oscillator. Balancing out the inputs, which it does do, is not needed in a broadcast receiver. So for a simple cheap receiver, multigrid mixers are the best choice. |
13th Dec 2009, 9:18 pm | #25 |
Hi Dave,
Thanks for the reply well written by the way. What I was referring to was your statement that if the valves are linear then the two signals cancel each other out due to the cathode connection.Linear valves do not give you 2nd order effects do they ? If you have two signals (a) on one grid and (b) ont'other ( and they are in phase) surely you just get addition. I have not sat down and reasoned dynamically what it would settle to but I would have thought that it would have given you 2 in phase contributions to the anode current Mike |
14th Dec 2009, 11:56 am | #26 |
If the valves are linear then each has a signal at its grid (a or b) and the 'other' signal at its cathode (b or a). So one valve sees a total signal of (a-b) and the other valve sees a total signal of (b-a) - because the cathode has the opposite effect to the grid. Adding them together we get a-b + b-a = zero!
Connecting the anodes together like this gives us an output with just even-order components. Leaving them separate, and taking the difference as the output (as in the differential pair) gives an output with just odd-order components. |
14th Dec 2009, 1:48 pm | #27 |
I think I know what your saying, to get the Most out of the anode, the Cathode would have to be at a Trough of a cycle (most negative) and the Grid would have to be at a Peak of a cycle (most positive) at the same time.
14th Dec 2009, 10:34 pm | #28 |
This is what I love about this and other technical forums. I asked a question which was more than adequately answered to my satisfaction, and then you guys take it and run with it. I have really enjoyed reading the subsequent discussions after my question was answered (although I hadn't looked for several days and was suprised to see the thread count up to 2 pages!). Thanks everyone for making this so interesting.
regards Charlie |
14th Dec 2009, 11:05 pm | #29 |
Yes, we do get a bit carried away at times!
16th Dec 2009, 5:26 am | #30 |
Interesting discussion, getting carried away is sometimes where good ideas come from.
I spose my best description would be to say that the ecc could be loosely compared to 2 fets with the drains connected as the common cathode, and the gates as the 2 control grids and the sources as the anodes. Dunno how you'd get a fet to self bias with diode action though. |
