12th May 2016, 6:01 pm | #1 |
Dansette Conquest auto mk2 (Actually a mk1).
Hi guys,
Just obtained the Dansette Conquest auto. There is power going to the unit, but no sound from the speakers. I changed the cartridge out, and still no sound. The valve seems to be working, as heaters come on etc. Could the possible problem be the smoothing caps? Thanks for any advice in advance. |
12th May 2016, 6:29 pm | #2 |
Re: Dansette conquest auto mk2
Have a read of the information in this article, it gives lots of advice, it's about radios but the fault finding section is good for record players.
http://www.vintage-radio.com/repair-...ion/index.html I doubt if the smoothing caps are causing the problem, they may well be faulty but there will be something else causing the lack of sound. Note all safety items for yourself and others. Frank |
12th May 2016, 7:29 pm | #3 |
It's no use guessing what might be wrong and changing components on that basis.
You need to get your meter out and take some voltage readings. There are dozens of posts describing how to do this. Many members here will help you to interpret the results. I suggest you start by measuring the DC voltage from chassis to each section of the smoothing cap.
12th May 2016, 8:48 pm | #4 |
When you say Dansette "Conquest" Mark 2, and as there is no photo, I am assuming it is the later version with one speaker and 2 valves. If it has 2 speakers and 1 valve, it's a Mark 1. Which one is it please? Edward
13th May 2016, 5:12 pm | #5 |
Re: Dansette Conquest auto mk2
Hi Edward.
It seems to be the MK1 with two speakers and one ECL82 valve. I have replaced the two capacitors in the photo. This didn't match the circuit board on the player, so i thought it was the MK2 as shown in the attachments. 64uF 10V 0.01uF 400V The first capacitor was loose and was measuring out of range, the second was showing signs of decay...so I replaced that too. Still no sound coming from the speakers. |
13th May 2016, 5:25 pm | #6 |
Well yes, this is definitely the Mark 1 "Conquest" so we now know where we are. Why did you replace those caps? Are you getting any sound when you touch the red lead on the cartridge or control grid on the triode of the ECL82. Have you checked the HT voltage coming from the contact-cooled rectifier or onto the output transformer primary? I agree in that it is unlikey to be the smoothing caps. In your case there are 3 caps in the one can, 2 off these are for smoothing - 16uf and 32uf. Edward
13th May 2016, 5:39 pm | #7 |
I get no sound whatsoever from touching either the the red lead or the cartridge. In fact I'm getting no sound at all. I replaced the caps because 64uF was loose one one end and out of range when tested. The second was decayed at one end.
Yes. The smoothing can is 32uF 275VDC x2 and one 25uF 25VDC. |
13th May 2016, 5:42 pm | #8 |
64uF is an odd value for a capacitor. I would have expected all the electrolytic caps in this player to be inside the aluminium can.
Follow Edward's advice and measure some voltages.
13th May 2016, 5:47 pm | #9 |
Re: Dansette Conquest auto mk2 (Actually a mk1).
Looking at the photographs the yellow capacitor was a Lemco 64uF 10V and the orange one was 0.01uF 400V.
13th May 2016, 5:52 pm | #10 |
OK. The only Dansette I can see with the combination of electrolytic capacitors you describe, an ECL82 and a solid state rectifier, as shown in your pictures is a Dansette Monarch.
13th May 2016, 5:56 pm | #11 |
I replaced with 67uF 10V and a mica 10nF 400V. That's why when I looked at the schematic for the mk1 these capacitors were not on the drawing. however when you look at the mk2 schematic then they appear on there.
13th May 2016, 6:01 pm | #12 |
It certainly says "Conquest" on the front panel.
Can you post a larger version of the circuit you show in post 5 please. It's too small to read.
13th May 2016, 6:03 pm | #13 |
The schematic posted by the OP shows it as Conquest Auto MK11, the Monarch shown in the R&TV Servicing books appears to have the same schematic, as Graham mentioned earlier.
Lawrence. |
13th May 2016, 6:04 pm | #14 |
It is possible someone has been making complete record players out of several others.
You will have to work with what you have. Do you have a meter? |
13th May 2016, 6:11 pm | #15 |
yeh i have a meter handy.....im on the sick after a operation so trying to fill my time in by getting this up and running. thanks guys for all the support and experience that comes with this forum.
13th May 2016, 6:16 pm | #16 |
As has been suggested by others, voltage readings next, if the valve heaters glow then DC voltages on all the valve holder tags except tags 4 & 5.
Lawrence. |
13th May 2016, 6:50 pm | #17 |
ECL82
1. 1.72mv fluctuating 2. 6.6mv 3. 153.0 v 6. 0.2mv fluctuating 7. 24.4mv fluctuating 8. 12.5v fluctuating 9. 0.966mv fluctuating |
13th May 2016, 6:58 pm | #18 |
I could be wrong but I suspect what you have identified as Pin 1 is pin 9 or else there's not supposed to be an ECL82 in that socket
Cheers Mike T
13th May 2016, 7:04 pm | #19 |
Yes you're righ,t just brought a schematic up for an ECL82.
1. 0.966mV fluctuating. (Control grid of triode section). 2. 12.5V fluctuating (Cathode of pentode section). 3. 24.4mV fluctuating (Control grid of pentode Section) 6. 0.2mV fluctuating (Anode of pentode section) 7. 153.0V (Screen grid of pentode section) 8. 6.6mv (Cathode of triode section) 9. 1.72mv fluctuating (Anode of triode section) thanks for pointing that out |
13th May 2016, 7:04 pm | #20 | |
The tags on the valve holder as viewed from underneath are the same as the valve pins as viewed from underneath as shown in this link for the ECL82: http://www.r-type.org/pdfs/ecl82.pdf That sheet shows the valve pin numbers as viewed from underneath and also the corresponding electrode connections within the valve itself, I posted that in case your not familiar with valve pin orientation arrangements. EDIT: Whoops...post crossed. Lawrence. |
