10th Aug 2015, 12:19 pm | #21 |
Re: Bush VHF64
10th Aug 2015, 3:47 pm | #22 |
Re: Bush VHF64
Me too !
I have a '94 here patiently awaiting a refurb. ( some chance ! ) I prefer the '94 as it has the lighter coloured cabinet with the cream trim. This one is near mint condition and should polish up a treat. It's even got both the knob brights )) Mark - any chance of your set's serial numbers and then I can add to my list of known survivors The production run of both the '64 and '94 seems to have been quite low, from the numbers I already have. Andy |
10th Aug 2015, 4:27 pm | #23 |
Re: Bush VHF64
I've got a couple more stashed away, Andy (you know how it is!). A rough one (220/01762) and another smart one whose serial number I don't have to hand at present, but which I can retrieve shortly.
How many do you think were produced? Nick. |
10th Aug 2015, 7:08 pm | #24 |
Location: Burntwood, Staffordshire, UK or Kabaty in Warsaw Poland.
Re: Bush VHF64
Andy - My serial numbers are:-
220/00811 220/01344 220/02125 220/01344 is unusual as it has 4 small feet instead of the usual wood strips at the base. Mark |
10th Aug 2015, 8:04 pm | #25 |
Re: Bush VHF64
Thanks Both !
Ive plugged these numbers into my spreadsheet which now reveals there are at least 24 known survivors : ( by all means add to this if you can folks ) 220 00036 220 00400 220 00508 220 00559 220 00693 220 00811 220 00929 220 01243 220 01344 220 01593 220 01697 220 01762 220 01945 220 02125 220 02646 220 03213 220 03914 220 04192 220 04200 220 04243 220 04361 220 04464 220 05711 220 05947 From lowest to highest yields minimum production run of 5912. I'm guessing possibly no more than 6000 as I've yet to come across a leading '6' and the lowest at 00036 suggests they started at 00001 ( as BUSH did with DAC90A ) Using my usual 'survival' stats of 1 in every 100 sets , we get a fairly healthy 40.6% Production numbers on the VHF 94 are even lower, as I've yet to come across a serial higher than 019XX ! Hence relatively more of these have survived Andy Last edited by yestertech; 10th Aug 2015 at 8:12 pm. |
10th Aug 2015, 8:48 pm | #26 |
Re: Bush VHF64
Andy - For your records and to account for another one, I have a scrap VHF64 chassis in the garage.
This has S/N 220/01917. Maybe you need to start a list of known non-survivors? Mark |
10th Aug 2015, 9:28 pm | #27 |
Re: Bush VHF64
I have 1 surviving VHF64, I'll post the serial # when I get back home.
They are fine sets but the tone controls are a little crude in their use, they are bass and top cut controls and could be better. The FM boxes all seem to have the heater leads for the ECC85 reversed from the service sheet, seems to make no difference when they are "corrected" 22 Hunts to change, keeps us busy! |
10th Aug 2015, 9:50 pm | #28 |
Re: Bush VHF64
You're not kidding - and now I can no longer see the darned things unaided a right royal pain in the proverbial.
Nothing quite beats that first power up and the trip up and down the dial once the refurb is done though ! I have useless FM signal strength indoors here, but before my external aerial blew down, it was amazing the difference it made attaching it to one of these. Fully closed ( and bright !) magic eye on all stations and no hiss. The down side was once the set was moved into the large surroundings of the lounge, I could then hear the 50 Hz hum ! |
10th Aug 2015, 10:00 pm | #29 |
Re: Bush VHF64
The serial number on my very nice VHF64, basically working but awaiting a full check is 381/00616
I'm not sure what that means in relation to the 220 series mentioned. Ian |
10th Aug 2015, 10:09 pm | #30 |
Re: Bush VHF64
10th Aug 2015, 10:42 pm | #31 |
Re: Bush VHF64
I have mine which belonged to an old friend of mine which he brought new
220 / 00377 another one I was given and I have restored and its at the wireless museum 220 / 00458 and the third one I restored for a friends girlfriend 220 / 02622 Mine is sitting between my hacker mayflower and my Ekco A274 and all 3 sound superb. |
10th Aug 2015, 10:56 pm | #32 | |
Re: Bush VHF64
Steve. |
11th Aug 2015, 7:24 am | #33 |
Re: Bush VHF64
OK Andy, my three are:
220/1697, 220/1762, 220/2262. I also know of another in captivity, which belongs to an elderly retired schoolmaster who was given it as a young man by his parents when it was brand new. He ran it into a Mordaunt Arundel speaker with Kelly ribbon tweeter. It sits in the corner of his study, unused but still admired. I will try to get his S/N when I next see him. I have to say that for a supposedly rare set, a lot turn up on eBay and sell for well under £50 which is surprising really. OTOH they are BIG and hence difficult to smuggle in past the wife etc.! Nick. |
11th Aug 2015, 11:58 am | #34 |
Re: Bush VHF64
It would be really interesting to know when Bush fitted the later output transformer with the hum cancelling winding. The trouble is, it's not easy to tell without taking the back off - although you could just listen for the background hum on gram.
Leon. |
11th Aug 2015, 12:10 pm | #35 |
Re: Bush VHF64
Good point.
Andy, could you accept the extra info for your database? If so, my ...2262 has the new-style OP transformer, not sure about the others. N. |
11th Aug 2015, 8:03 pm | #36 |
Re: Bush VHF64
Re my post #30, I strongly suspect my "VHF64" is actually a bit of a mongrel with a VHF94 chassis (and serial number) and VHF64 externals. I read in the archives that the 64 and 94 chassis are identical with some cosmetic differences in the colour scheme. I'm perfectly happy with this and looking forward to changing the dubious capacitors and aligning it properly. I have a good set of test equipment to aid.
Ian |
11th Aug 2015, 9:13 pm | #37 |
Re: Bush VHF64
Well you say that, but others have noted how several significant circuit design modifications were introduced during the manufacturing lifetime of (certainly) the 64 to address issues and problems, and maybe the 94 too, or at least the latter will include all of the 64 mods. So they can't be identical. I'm not trying to split hairs, really, but there will be clear differences in circuitry.
13th Aug 2015, 3:33 pm | #38 |
Re: Bush VHF64
Hello Andy.
I have 2 Bush VHF64. S/N Are. 220/01663 220/01632 Regards Kev. |
13th Aug 2015, 4:18 pm | #39 |
Re: Bush VHF64
Andy are you wanting 94 serial numbers too?
13th Aug 2015, 10:51 pm | #40 |
Re: Bush VHF64
Thanks everyone for all your input
I'm more than happy to add extra details to my database to reflect things Like the smoothing Modifications on the VHF 64 I've often wondered how bush allocated the serial prefix labels to these two chassis types as they were made , as they were effectively identical until the knobs were put on ready for the associated cabinet. It's not impossible that the odd '381' chassis could have made its way into a '64 cabinet and vice versa during manufacture. There's one out there somewhere on which I did this swap about 10 years ago for a collector friend who had about a dozen of them over time.this was not recorded, alas. I'll gladly take the VHF 94 serial numbers if offered ( or any other makes/ models ) thanks Andy |
