9th Jul 2010, 1:59 am | #41 |
Re: Radiomobile 4200 help
Hmmm - put another signal in at the volume control and let's see if this also comes out distorted.
Cheers, Steve P.
9th Jul 2010, 11:27 am | #42 |
Is it possible to unplug the vibrator, leaving the battery connected to supply LT, and provide HT from a bench supply connected to the smoothing capacitors? This will help you to determine if there are vibrator problems.
9th Jul 2010, 11:29 am | #43 |
Looking back I see you don't have a bench power supply. What about some PP3s in series?
9th Jul 2010, 7:08 pm | #44 |
Well, mystery solved.
It sounded and felt so much like a "that cap" fault that I decided to test the voltages at the ends of them. I found that the brand new poly cap connected to the cathode of the splitter valve was a dead short and had 50 or so volts on the other end of it. Replacing the cap has brought the HT up to spec (more or less) and there is now a healthy negative voltage on the grids of the o/p valves. The sound is much better although I haven't had time to try it with a CD input or with a really suitable speaker. Who would have thought it? Thanks for the help, all. Paul |
