Old 26th Jul 2020, 4:15 pm   #1
Zooter80
Default TEAC X-300 reel to reel
Hi have teac x300 reel to reel can not get it to record cleaned heads sill no joy help please
Zooter80 is offline
Old 26th Jul 2020, 5:15 pm   #2
Andrew2
Andrew2's Avatar
Default Re: TEAC X-300 reel to reel
Are the VU meters wagging about on record or resting at zero? Give us all the info you can.
Andy G1HBE.
Andrew2 is offline
Old 26th Jul 2020, 6:17 pm   #3
DMcMahon
DMcMahon's Avatar
Do you know any history of the unit, such as, was it working OK but suddenly stopped recording ?
DMcMahon is offline
Old 27th Jul 2020, 11:13 am   #4
Zooter80
Hi thanks for geting back when putting in to record you can set the line in on uv but when you press the sorce button to tape the uv meters die down and no recording hope you can help thanks
Zooter80 is offline
Old 27th Jul 2020, 1:37 pm   #5
DMcMahon
DMcMahon's Avatar
Does it erase a previous recording ?
If erase is not working it could be a problem with the Bias Oscillator, which also produces the Record Bias signal that is used to record.
DMcMahon is offline
Old 27th Jul 2020, 8:29 pm   #6
Zooter80
Thanks for that i don't think i can fix my self i will take it to a tech in my where i live if i can find one thanks
Zooter80 is offline
Old 27th Jul 2020, 8:40 pm   #7
AC/HL
AC/HL's Avatar
You could try a post here: https://www.vintage-radio.net/forum/...play.php?f=145
AC/HL is offline
Old 28th Jul 2020, 9:02 am   #8
Zooter80
Hi andrew 2 do you know of a good tech who could fix it for me in my area as you are not far from me hope you can help thanks
Zooter80 is offline
Old 30th Jul 2020, 2:25 pm   #9
unitelex
Hi
I can repair it for you and I am local to you in South Manchester
I will send you a PM
Best Regards
Chris
unitelex is offline
