25th Jul 2020, 3:51 pm | #1 |
Vintage Philips stereo cassette recorder
I acquired this old 1970s Phillips tape recorder in the loft with twin stereo mics. I have opened it up and found each belt has understandably perished as it hasn't been used since 1986. I plugged the mics in to see if they still sent a signal and they do as the meters are responding. If not worth that much I will just sell on Ebay but I must say I do like the look of it with the wooden edges.
What I would like to know is if this is worth restoring, is it high quality or average ? Also, as I have a music studio, I would like to use the stereo mics if they are decent enough BUT they don't have phones connections, just a 5 pin which means I can't use them in my AI on my PC. Any help would be appreciated. Thanks. |
25th Jul 2020, 5:06 pm | #2 |
Re: Vintage Phillips stereo cassette recorder
It's an early Philips stereo cassette deck, not bad quality by the standards of the day but not really HiFi. It predates Dolby B and instead uses the Philips Dynamic Noise Limiter, a sort of playback noise gate. They are quite sought after by collectors but aren't worth hundreds.
The mics are just consumer grade dynamic mics of the era, not awful by any means but nothing special. The connectors on this deck are DIN. |
25th Jul 2020, 5:13 pm | #3 |
Both very low-fi to be honest. Of 'collectors' interest only, and not much of that I would think.
25th Jul 2020, 5:23 pm | #4 |
Actually these decks don't sound at all bad when working properly with good tape stock, but they're nowhere near as good as the Japanese decks from people like Akai and JVC which arrived a few years later. They're an interesting stage in the evolution of the cassette medium though.
25th Jul 2020, 6:23 pm | #5 |
Re: Vintage Philips stereo cassette recorder
It looks like the "N2506" trim strip on the front of the cassette flap has been lost:
https://www.cassettedeck.org/philips/n2506 These were also used in Dynatron equipment of that era. |
25th Jul 2020, 7:11 pm | #6 |
Oh yes I know about that as I kept it when it fell off. Going to glue it back.
Thanks folks. In that case I may just sell the two on Ebay for collectors to restore. |
25th Jul 2020, 7:39 pm | #7 |
I can confirm as suggested above it is a Philips N2506 (it has DNL...Dynamic Noise Limiter) fitted. They were reasonably well regarded in their day but could hardly be regarded as true hi fi since their top response was around 12khz. They did sound good however and the DNL made a huge reduction of tape noise. Note that DNL only operates on playback.
Repaired a good many of those when I was at Philips....not because they were unreliable, far from it, but because there were so many of them about.
25th Jul 2020, 7:51 pm | #8 |
The DNL system did produce very obvious noise gating with a lot of material though - it wasn't very subtle.
26th Jul 2020, 10:33 am | #9 |
I had one bought from the Philips' Staff Shop and found they gave a very good sound for an entry-level product. Of course the recording levels of both channels are ganged by the single slider pot. The unit is very well built and, at its price point, was very good value. If it were mine I would keep it and just use good quality Ferric (high-output) and Chrome tapes. The slider pot cleans up well with Servisol. I recorded a lot of live music with (when fitted onto their stand) those omni-directional microphones with excellent quality. They are very sensitive.
Edward. |
26th Jul 2020, 8:37 pm | #10 | |
A later model, the N2507 which in many ways resembled the N2506 was designed for chrome tapes.
26th Jul 2020, 9:18 pm | #11 |
TDK ADs were the best option to use with these once they became available. They were ridiculously underbiassed, but sounded better than anything else available for such decks in the mid 70s.
30th Jul 2020, 1:59 pm | #12 |
I am going to sell it but keep the stereo mics but as it is 5 pin din, is there some kind of adaptor I can get to turn it into 2 x L/R jacks ?
30th Jul 2020, 4:17 pm | #13 |
I've just put " 5 pin female din " into the auction site and many different results came up depending on which way you want to go.
30th Jul 2020, 4:25 pm | #14 |
I think you will get more for the decks if you sell them with the supplied mics. They aren't a lot of use nowadays - a cheap condenser mic will knock spots off them.
Be careful repairing damage if you're not an expert. A collector will probably want to deal with it themselves. |
