Old 26th Jun 2020, 6:10 pm   #21
real0real
Default Re: Marconiphone 222 Restoration
Hi
Update
Have finished the wiring today, was unable to get correct wire colours but will buy some shrink sleeving and change wires to correct colouring bit later, as it is wired at the moment
Blue wire replaced ------ Yellow / Black --1.5V
Brown wires --------- replaces the 2 Black / Red wires (which were linked together externally) to 1 black/red wire ------166 v
Red wire still Red wire ------------ 72v
Grey wire replaced ------yellow wire ------ 9v
Connected up and plugged into the battery eliminator today and tested
Results ;-
The instrument panel light has has come on o.k (no smell of burning or anything)
could not see any illumination from valves (but very bright today at moment)
Have noticed that if you touch / wiggle the wires plugged in to battery eliminator a clicking noise can be heard from speaker
Have attached pictures of how wired into battery eliminator think i have connected correctly ?
Radio not working at present
Any suggestions
Clive
ID:	209536   Click image for larger version
ID:	209537   Click image for larger version
ID:	209538   Click image for larger version
real0real is offline
Old 26th Jun 2020, 7:19 pm   #22
Gabe001
You can work out if the way you wired the battery eliminator is correct by measuring anode and screen voltages across the various valve pins and comparing them to the ones specified in the trader sheet. If the valve heaters are on the the bulbs are on you've done something right.
Gabe001 is offline
Old 26th Jun 2020, 7:59 pm   #23
Ed_Dinning
Hi, voltages on HT-, LT- and GB+ are all commoned on the eliminator, but may not be in the set. you should plug in the HT- and GB+ wires.
The QPP/ Screen grid wires are not connected to W,X, etc
See if that helps
Ed
Ed_Dinning is offline
Old 27th Jun 2020, 12:44 pm   #24
real0real
Hi Ed
Bit confused as plugged in all the original leads that exit from the set into the terminals on the battery eliminator which i think are the correct terminal points
(should mention that there was not a yellow/black lead from originals wires only black possible yellow has faded away to being just black of the original wires but now have replaced with blue wire), all the others were o.k and colours were just about visible as fabric braiding rotted away
do i need to make a couple of leads to feed in for GB and HT inputs ?
Clive
Old 27th Jun 2020, 9:21 pm   #25
Ed_Dinning
Hi Clive, there is usually a bunch of leads together on these sets that all eventually connect to chassis. These are the GB+, HT- (sometimes via fuse bulb) and LT-.
It should work with only the LT- connected but have a check for the other leads and see.
There should also be the leads from the output valve screen grid connections.
Time for a few voltage readings. Any clicks or crackles?
Ed
Old 27th Jun 2020, 11:38 pm   #26
real0real
Hi Ed
Checked valves with the lights switched off tonight , anable to see any light from them so possibily not working/powering on
Am getting slight click / crackle noises if i switch over channel knob on front of radio for a secound , plus tap the wire leads that fit into the battery eliminator (wiggle)
Have checked voltage exiting battery eliminator with the leads plugged in , and to chassis of radio , for the red lead where sould be 72v only getting a reading of approx 10v and for the 166 v only getting a reading of approx 125v , could this be a fault or just power drain when under load ?
Clive
Old 3rd Aug 2020, 9:28 pm   #27
hillmanie
Originally Posted by Herald1360 View Post
If the battery prices seem exorbitant, they wouldn't have been much different (if not more) in real terms back in the day. There're good reasons why battery operated valve sets disappeared practically overnight when transistors came along!
Quite correct. The 'dry battery' - 120v cost 12/6d when some rural farm workers got only 10/- per week. The 'wet battery' (2V accumulator) had to be hawked to the village equivalent of the drug store to be charged (6d) All this applying to remote rural folks of course
TT
hillmanie is offline
Old 4th Aug 2020, 6:57 am   #28
Gabe001
Did you ever get this working Clive?
Gabe001 is offline
Old 4th Aug 2020, 9:12 pm   #29
Ed_Dinning
Hi Clive , just seen your post of 27 June, did you resolve the voltage readings?
Ed
