Old 5th Mar 2017, 4:16 pm   #1
MrBungle
MrBungle's Avatar
Default How far does a 50nW (legal!) FM transmitter actually reach
I'm considering building myself a simple 50nW FM stereo transmitter for the sake of broadcasting an mp3 stream from a Raspberry Pi Zero W as there is literally nothing on commercial radio of interest now for me.
Plan is to use a USB DAC IC, an NJM2035 to encode and then a MAX2606 as the transmitter with a suitable LPF and an attenuator to keep the ERP legal. I have the necessary equipment and expertise to test that this is compliant.
However I'd like to understand with the respect of propagation if this is even feasible as a transmitter or not to reach approximately 10m. Propagation is not my strongest area.
My WiFi strength is similar at around -43dBm at the same distance and this is usable with a good antenna.
MrBungle is offline
Old 5th Mar 2017, 4:23 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: How far does a 50nW (legal!) FM transmitter actually reach
You cannot build a legal transmitter no matter how feeble the power. They need to be CE marked to be legal.
The range of a 50nW TX will depend on the environment and aerial used, but it should cover 10m if there are no screening walls in the way. It seems a bit pointless to keep to this limit though. It would make more sense to increase the ERP until you have the range you need, while not radiating beyond your boundary.
paulsherwin is offline
Old 5th Mar 2017, 5:09 pm   #3
As Paul says, homebrewing these is *technically* a no-no unless you're intending to submit your finished model to an approved test-house for "RED" certification.
http://eur-lex.europa.eu/legal-conte...002&from=EN%20
Though I suspect quite a few of us have a "modulated test-oscillator" in our workshops.
Given that you can buy legal versions of these transmitters for under a tenner, why bother building your own? I've got one here that's built into a car cigarette-lighter plug along with a 12V-to-5V USB charger. Couldn't have sourced the parts for the amount it cost me.
Old 5th Mar 2017, 5:15 pm   #4
paulsherwin
I have a car MP3 player which accepts SD cards or USB disks and also has a line input. It outputs on any FM frequency and sits in the cigarette lighter socket. It even has a basic remote control. I think it was about £3 including postage from China.
It was CE marked, though that should obviously be taken with a pinch of salt.
Old 5th Mar 2017, 7:11 pm   #5
MrBungle
MrBungle's Avatar
Thanks for the info all, much appreciated. Will find a CE marked one then and naively assume it's legitimate
A bit sad really as the CE mark means literally nothing in the scale of things as the various dubious character spacings over the years have indicated...
I was only going to build one because I have some bits lying around and some time to burn at the moment while I'm waiting for some other parts to be delivered.
MrBungle is offline
Old 5th Mar 2017, 7:24 pm   #6
As Paul said, they are very cheap on ebay etc. add a bit more wire to the aerial and they go a surprisingly long way.
Old 5th Mar 2017, 7:49 pm   #7
MrBungle
MrBungle's Avatar
I have ordered one from China now for a whopping £2.70. I'm never failed to be impressed by the price of stuff coming from that part of the world. I'll take it to bits and integrate it with this. It has a tuning selector up/down controls and a display and a stereo input so is spot on.
Got the USB DAC working early evening. Used a PCM2707 DAC (from a canned HiFi project I started a year ago) on a tiny SMD matrix board from RS/Roth Elektronik. Required 6 SMD capacitors, 8 SMD resistors, a crystal and a voltage reg and I soldered it directly to the USB pins on the Pi Zero with kynar. Both are screwed down to a piece of plywood as a "master breadboard". Worked first time for the first time ever. Nearly fell off my chair! My eyes hurt now though. This was my first SMD attempt ever past a few minor things.
MrBungle is offline
Old 5th Mar 2017, 8:07 pm   #8
stevehertz
stevehertz's Avatar
You want it CE marked? no ploblem, we put CE sticker on it!
stevehertz is online now
Old 5th Mar 2017, 9:15 pm   #9
ionburn
ionburn's Avatar
Personally I would take CE marks with a pinch of salt as they do not indicate what directive something complies with. In the EU an item has to have a CE mark in order to be sold (as far as I am aware). Really something has to have a test house mark (or further info) to enable scrutiny.
I don't remember details but I think if something is custom made for a particular purpose it does not require formal CE marking, at least for internal use. In the NHS we made many items of equipment but never had issues with CE marking (although the requirements for were investigated, but it was long ago so I don't remember details).
A point to think about, as the CE mark is a EU thing, what will it be replaced by?
ionburn is offline
Old 5th Mar 2017, 9:24 pm   #10
paulsherwin
EU rules are enshrined in UK legislation - the EU has no lawmaking powers of its own. However, once the UK leaves the EU then UK politicians and courts will be able to repeal or amend the legislation, which they can't do at the moment.
No discussion of Brexit here please!
Old 5th Mar 2017, 10:00 pm   #11
CambridgeWorks
CambridgeWorks's Avatar
Have you the instrument to measure 50nW accurately, assuming you did make one? Just a thought, not wanting to be sarcastic at all.
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd
CambridgeWorks is offline
Old 5th Mar 2017, 10:01 pm   #12
CambridgeWorks
SORRY. Just saw this "I have the necessary equipment and expertise to test that this is compliant.". Put my brain into gear before typing!!
Old 5th Mar 2017, 10:07 pm   #13
MrBungle
MrBungle's Avatar
For ref, I've got an HP 436A power meter which is good to -70dBm.
MrBungle is offline
Old 5th Mar 2017, 10:34 pm   #14
Wendymott
Wendymott's Avatar
My understanding of the "CE" mark is that.... IF you intend to sell commercially any electronic product, whether sending or receiving, it must comply with certain tests, such as EMC, Safety, RoSH and if battery powered, then more regarding the battery construction, "IF Internally" fitted. However for home use, CE does not become necessary.
To get CE Certification, Test Houses such as Alphatec,Airbus Defence... etc etc which are registered by UKAS. All test houses charge an arm and a leg...
Alternatively you can "self Certificate", which means, you can do the tests yourself and hope nothing goes wrong.
Should get out more.
Wendy G8BZY
Wendymott is offline
Old 6th Mar 2017, 12:48 am   #15
kalee20
I think you'd do this by measuring the amplitude of oscillation at the aerial, and appeal to maths to calculate how much power is actually radiated, knowing the geometry of the aerial.
50nW, collected for 20 years, would be enough energy to light a LED for about a second.
kalee20 is offline
Old 6th Mar 2017, 12:34 pm   #16
MotorBikeLes
I don't do any "local transmissions" myself, but on one occasion 20+ years ago, I used my NordMende SC384 stereo coder signal generator to do the job. Very much pre-CE, I would happily use that with a telescopic rod soldered into the (unusual) output socket. That is how I use it in the workshop for general testing, though I have not used it for a proper FM/Stereo alignment for maybe 30 years.
Les.
MotorBikeLes is offline
Old 7th Mar 2017, 12:18 am   #17
Jon_G4XJC
Ummm, my answer would have been, If your have a clear frequency & sensitive receiver ## Some considerable distance ##
I had a little one, badged as Realistic ( internal AA battery ) CE certified (no external connections exception flying lead for audio in) " transmitter ' positioned in kitchen ( none elevated site ) Which could be received up to 1/4 mile away (fully quieting stereo) Received in a built up area, on my car stereo.
My guess was that the flying lead was radiating. because repositioning it, effected the coverage area '-)/
De Jon ..
Jon_G4XJC is offline
Old 8th Mar 2017, 11:27 am   #18
Mach One
Mach One's Avatar
The ones that I have had in recent years have all had a very small range (a matter of feet) when used on internal batteries but once I plug them into a power supply of sorts (either mains or in-car) the range extends all around the house and into the garden or in the car can be heard quite clearly in other cars. Any power output that is quoted seems to be quite nominal.
Mach One is offline
Old 8th Mar 2017, 12:17 pm   #19
HamishBoxer
HamishBoxer's Avatar
I used to think but never tried putting an aerial on the o/put of an RF modulator VCR.Not sure how far around or if the house it would travel.
HamishBoxer is online now
Old 8th Mar 2017, 3:40 pm   #20
GMB
GMB's Avatar
If you want to see how far the "legal" ones transmit, just tune your car radio to the bottom-most frequency in the FM band and drive along a motorway.
I bought my wife a thing to transmit from an iPod to a nearby FM radio - for car use. By default they tune to the lowest frequency and as that spot is usually empty I though it a good choice. Sadly I had bought a fully legal one, but it seems other cars also use these devices - but clearly don't have the same low output!
By the way, the bigger snag turned out to be very low deviation so it didn't work so well for that reason.
GMB is online now
