28th Jan 2020, 11:44 am | #1 |
Replacement Rubber Platter for Dansette Popular 1962
Please help! I need to find a replacement platter for this player.
I have tried a UA8 and a UA14 rubber mat on this player which neither fit (too big). The deck has no rubber on it anymore, all I have is 3 holes where it would affix. However I don't mind if I have to glue this. |
28th Jan 2020, 12:09 pm | #2 |
Re: Replacement Rubber Platter for Dansette Popular 1962
Post a picture of the turntable fitted. It may help someone to advise what turntable mat (correct term) is needed. If a request is posted in the ;Sets, Parts, and service information wanted section, another member may have something suitable.
28th Jan 2020, 12:32 pm | #3 |
Also there are a number of readily available materials which can be used as mats if appearance and/or originality are not crucial.
Alan |
28th Jan 2020, 12:39 pm | #4 |
A 7" or 8" pizza base will do pro-tem. Paint with emulsion to match. These are extremely hard to source, the 10" and 12" ones are much more common.
Edward. |
28th Jan 2020, 12:50 pm | #5 |
Spookily, and in spite on my Post just made, one of the has just appeared on eBay for £1.99! Go for it.
Edward. |
28th Jan 2020, 1:02 pm | #6 |
Any chance of a link to the eBay item?
28th Jan 2020, 1:19 pm | #7 |
I imagine it's this one:
https://www.ebay.co.uk/itm/Dansette-...IAAOSwTUBeGzqa It's an auction format so final price unknown at this stage. Alan |
28th Jan 2020, 1:46 pm | #8 |
if you have a poundland near you they do a packet of self adhesive round pads of
various diameters you could place these around the platter |
28th Jan 2020, 2:25 pm | #9 |
... probably one of the best ways of supporting vinyl in terms of sound reproduction. Probably won't make much difference to a Dansette.
Alan |
28th Jan 2020, 4:30 pm | #10 |
We also have the Crosley turntable to thank for the availablity of 17cm rubber turntable mats on eBay for £4.99 including postage.
Martin
BVWS Member |
29th Jan 2020, 11:13 am | #11 |
Just wanted to follow up in here and thank people. I managed to source a mat via eBay thanks for this forum.
Now all I have to do is get brave enough to look at this block of asbestos. I think we used to build everything from it. |
29th Jan 2020, 12:30 pm | #12 |
There shouldn't be any asbestos in a Dansette. Where about is it?
29th Jan 2020, 6:01 pm | #13 |
That white block / asbestos been mentioned numerous times on here, to absorb the heat from the valves on the base board / hardboard, not sure if its ever been confirmed if its asbestos.
left alone it should be fine some said you could coat it by painting PVA glue over it, if it is asbestos it possibly cost more to have it "professionally" removed than what the record players worth. Personaly if it looks ok not crumbling etc id leave it there |
30th Jan 2020, 4:54 pm | #14 |
Had a few from these guys and are excellent EBay ref 113625327854
IKEA do circular place mats which can be cut to size and are dead cheap.
"I really am seriously downsizing " |
22nd Feb 2020, 2:07 pm | #15 |
I worked at BSR but in the component making side of the press shop .Know a bit about these i saw so many made back in the 1960 to 1983 .
