8th Jun 2011, 4:35 pm | #21 | |
Re: Stereo Demodulator issue. Baffled!
8th Jun 2011, 4:36 pm | #22 | |
8th Jun 2011, 4:50 pm | #23 |
Ok, I didn't realise that there are two designs with the same name. If your power amp is also DC-coupled then you may have trouble. In most setups every item has coupling caps in case someone omits them, so half of them are unnecessary. Your setup may be the exception which proves the rule - none of them have caps because each assumes that all the others will do DC-blocking.
8th Jun 2011, 5:05 pm | #24 |
You said the Pass B1 buffer is "DC Coupled" is this correct, as I assume you mean the signal path? Different from the circuit Dave has posted a link to?
I agree with Dave that a notch filter would be good, or a low pass filter with a steep roll off above 20Khz. Have you tried the output from the decoder into any other amplifier to see if you get the same effects? |
8th Jun 2011, 5:17 pm | #25 | |
8th Jun 2011, 5:38 pm | #26 |
Plugged it into a Pioneer A300X integrated amp, it plays fine, but when I crank the volume up, I get the hum, and then the speaker protection circuits kick in, so it seemed pretty certain to be DC we are dealing with here.
Then, I measured it. In MONO mode, we are talking about 0.14mV(ish) per channel. Perfectly acceptable of course. In STEREO, we are dealing with 4.3vDC on the left phono and 4.11vDC on the right. OK, so that's it then. Many thanks to you all. Anybody care to suggest an optimum cap value? The theory on DC blocking caps is staggeringly complicated. Last edited by LucasAdamson; 8th Jun 2011 at 5:45 pm. |
8th Jun 2011, 5:44 pm | #27 |
That sounds potentially very nasty!
If your entire amplifier chain is DC coupled and you feed in DC to the input, the speakers will get a good dose of DC applied to them. The audio will sit on top of the offset, so there is still an output, but the bass drivers will be displaced from their normal position and, much worse, the current will quickly heat up the voice coils which won't do them any good at all ! Pete |
8th Jun 2011, 6:37 pm | #28 |
If your DAC has 2uF caps on the output and that works fine, use the same value on the stereo decoder outputs. I just hope you haven't done too much damage to those voice coils!
Peter |
8th Jun 2011, 7:28 pm | #29 |
I don't think I've burned out any of the coils, judging by the sound. They should be OK.
I will try 2uF, as that often seems to be value chosen for this purpose. I have no idea about the deciding factors in this though - ie how much capacitance for how much DC to remove. |
8th Jun 2011, 7:32 pm | #30 |
No connection whatsoever between capacitance value and how much DC to remove - that just affects the required capacitor max voltage.
The cap value is set by the desired low frequency rolloff as the cap and the resistance of whatever follows form a CR high pass filter. Google will help you. |
9th Jun 2011, 1:01 am | #31 |
OK, so I had some very old (1970s) 2uF polyester bipolar speaker crossover caps left over from a speaker project. I bunged them in, and the DC is gone, but....
The amp now sounds like any other horrible crappy cheap transistor tuner. Gone is the lovely lush sound which was there when I had 4.5vDC hacking away at my speakers. Before these caps, it was just as the MONO channel, lovely and lush, rich and smooth, now it's R-O-U-G-H. Now, I know that these caps are a bit crap, even though they are polyester - I think they're the type where they spray metal particles onto polyester and then roll it up, not real rolled foil in oil types, but I cannot live with them. Anyway.... I had bought two Silver Mica 850pF caps for using as de-emphasis replacements for the stereo channel - would they work well for DC blocking as well? Will they attenuate low frequencies too much? They are quite tiny values but I am told excellent quality for signal. The first resistors in the pre-amp are a 220K shunt and a 220R series, if that helps determine the effect of the CR. I still don't quite get why the DC wasn't ever present, but only came on suddenly when the volume was in the 9pm position. Many thanks radio dudes, Lucas |
9th Jun 2011, 2:30 am | #32 | |
As a sidebar, I see that the B1 buffer is described as not having negative feedback: "Given the simple task, it's pretty easy to construct simple buffers with very low distortion and noise and very wide bandwidth, all without negative feedback." Ummm....doesn't a follower (whether cathode follower, emitter follower, source follower, or voltage follower) have more-or-less 100% negative feedback, or I am missing something here? Cheers, |
9th Jun 2011, 2:41 am | #33 | |
Cheers, |
9th Jun 2011, 3:00 am | #34 | ||
Yes, DC was ever present, but it still amazes me that it sounded lovely and then suddenly Bzzzzzzzzzzzz. |
9th Jun 2011, 9:26 am | #35 | |
The best coupling cap value will be determined by the impedance of your circuits, but I don't think there is enough information available yet. Cheers Billy |
9th Jun 2011, 9:28 am | #36 |
I still have a sneaky feeling it is to do with your supply. Perhaps I have missed a posting but have you isolated the supply completely from the tuner and fed the decoder from an external supply, even batteries would be fine for a quick test!
Why not feed your new decoder from the existing decoder feed and if necessary build a little stabiliser with an LM317.
Cheers, Trevor. MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member Last edited by murphyv310; 9th Jun 2011 at 9:37 am. |
9th Jun 2011, 10:19 am | #37 |
I agree with Trevor. (And Al)
See posts (Al) no3, (Trevor) no4, and (my post) no8. The OP seems to be ignoring the power supply, and considering everything but. A power supply is the root of everything; power supply problems can give rise to the weirdest of faults. |
9th Jun 2011, 10:30 am | #38 |
It was DC in the signal, now blocked with 2x 6,3uF polypropylene caps. The radio no longer distorts or gives hum beyond 9pm position, as the DC is gone, but it is still VERY loud. Quite why, I still haven't yet determined. It seems that the circuit diagram for UA758 is either incomplete or makes the assumption that DC blocking will be present in the amp signal input (which would normally have been the case to be fair). The loudness is another matter. The power supply, you say wisely. I will try an external battery source and report back.
9th Jun 2011, 10:59 am | #39 | |
Many thanks Lucas |
9th Jun 2011, 11:02 am | #40 |
Hi
The circuit diagram of the UA758 certainly does look incomplete. It would seem that it is simply an application circuit design, rather than a full constructional design. There is no thought given to interfacing to an amplifier. If I were trying this. I would start by coupling the audio to an amp via a pair of 10uF electrolytics (one per channel of course and +ve to the UA758 outputs where the 4.5ish Volts are) this will remove the DC content. Then if the output is still too loud try a potential divider from the -ve end of the caps to deck, and take the output from the center of the divider. In fact a 100K preset pot as the divider (take the output from the wiper), that way you can balance the levels to match that of the MONO output. Pete Last edited by G0PKH - Pete; 9th Jun 2011 at 11:25 am. |
