9th Oct 2019, 5:50 am | #21 | |
Re: Modifying discriminator coil for narrow band FM.
9th Oct 2019, 7:46 am | #22 |
Indeed. Back in the day (1985 and through the 1990s), 2 of the DFW FM stations, one the PBS outlet and the other the local classical music station, used minimal compression, and I hardly ever listened to other than these when it came to FM. The commercial FM stations were very heavily compressed, and sounded noticeably louder than the other two. So I guess I was comparing NOAA weather radio with what were relatively quiet FM references. PBS had two SCAs, each taking 10%, so with 10% for the pilot tone, maximum signal audio was modulation ±52.5 kHz. And if we assume a 30% average, that’s just ±15.75 kHz.
Cheers, |
10th Oct 2019, 7:17 pm | #23 |
Well that's given me some encouragement to try a few quick test circuits. As wideband IF strips are typically stagger tuned, it may be possible to tweak them up a bit to obtain a more peaky response more suited to NBFM. As has been said already, any audio levels could be corrected by introducing a bit of gain, if the discriminator noise level isn't too high. If the coils can't be used "as-is" out of the spares box, it's probably a non starter, as there are probably better solutions available, using more suitable components.
Alan. |
