Old 20th Jul 2018, 1:36 pm   #1
Nanozeugma
Nanozeugma's Avatar
Location: London, UK. Bury, Lancashire quite regularly :)
Default PYE PE80 Waveband Shutter Cable.
Hi All,
I'm currently working on a recently acquired PYE "International" radio, of 1953.
The steel cable which connects the waveband switch shaft (one end) to the display shutter (behind the tuning scale glass).....
..... is in the bottom of the cabinet.
I would imagine that the sequence of events was that the shutter jammed and considerable force was applied in an attempt to free it.....
..... as the cable (still attached at the waveband switch end) is frayed / unravelled in the middle - but otherwise intact.
Q.
Could anyone suggest a source of "7/42 SWG stranded, high grade, tinned steel wire" or equivalent as specified in the manual please?
N.B. Image of the relevant service manual illustration attached.
Many thanks in advance for any assistance offered.
Thermionic Emission, warms the cockles of your tubes.
Nanozeugma is offline
Old 20th Jul 2018, 2:36 pm   #2
Reelman
Reelman's Avatar
Default Re: PYE PE80 Waveband Shutter Cable.
I don’t know if it would work but Bunnings sell picture hanging wire in various thicknesses.
Peter
For example......
Reelman is offline
Old 20th Jul 2018, 2:48 pm   #3
Nanozeugma
Nanozeugma's Avatar
Thanks for the thought
Old 20th Jul 2018, 2:52 pm   #4
Nanozeugma
Nanozeugma's Avatar
Doing a bit of research, it seems that 42 SWG equates to 0.102mm.
The best I have been able to come up with so far from a U.K. supplier is Beadalon 7 Strand Stainless Steel Wire for Jewellery Making, 0.012" 30 feet for £2.98 delivered.
You obviously can't solder stainless steel wire, but I guess you could crimp on a small ferrule...
Old 20th Jul 2018, 5:32 pm   #5
Boater Sam
Bike gear cable for Sturmey Archer hubs is about that size I think.
Brake cables are thicker.
I think you could solder stainless with Laco flux or superglue?
Boater Sam is offline
Old 21st Jul 2018, 2:12 pm   #6
Silicon
Have you looked in guitar shops, etc?
Some of the new high tensile plastics cords may do the job (i.e. Spectra).
Silicon is offline
Old 21st Jul 2018, 2:51 pm   #7
David G4EBT
David G4EBT's Avatar
Yes, they're variously known as 'cord ends' 'crimps' & necklace tips'.
I mentioned them recently in this thread:
https://www.vintage-radio.net/forum/index.php
(You might also get some suitable stranded stainless steel wire from a fishing tackle shop).
Good luck with it.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 21st Jul 2018, 2:54 pm   #8
G6Tanuki
G6Tanuki's Avatar
Seconded on the fishing-tackle shop as a possible source: the stuff is used as 'tracer' wires on things like pike-lures (pike will bite through most things but stainless-steel wire usually defeats them).
G6Tanuki is offline
