20th Jul 2018, 12:57 pm | #1 |
Dual party P1008
Hello all. I've been having issues with the above mentioned record player and was directed to this site in the hope I can find help obtaining a certain part. I acquired a dual party off ebay a short while ago, but someone has been inside it and removed the dual pot bass control and the components that were attached to it. I've acquired the components but I can't find a suitable pot for the life of me. It's supposed to be dual gang 10megohm according to the service sheet. I've searched everywhere on the net but no joy. If anyone can tell me where to find one, or some sort of equivalent I would be most grateful. Thank you.
20th Jul 2018, 2:33 pm | #2 |
Re: Dual party.
Was this the Dual P1008 AV26 "Party" recently sold as spares and repairs?
If so, the circuit is available on Radiomuseum. If not, which model is it? |
20th Jul 2018, 3:50 pm | #3 |
Re: Dual party.
Hi there Bill. Yes it is the one from eBay. I've had it just over a week. I managed to get the service sheet and have managed to get the components which were missing. I just can't for the life of me find a pot for the bass control. I've attached a small portion of the service sheet showing that it is a 10m pot which is needed. But it seems they don't exist anymore.
Kev. |
20th Jul 2018, 7:17 pm | #4 |
Re: Dual party.
It appears to be standard physically, but such high values aren't common these days. You might have to have one made, but that won't be cheap. The other option is a dummy pot, and fixed resistors for a compromise setting. Try a wanted post, you never know!
20th Jul 2018, 7:43 pm | #5 |
Re: Dual party P1008
Looks like it's used as a variable resistor rather than a pot, so depending on which end of the control range you prefer, subbing the highest value pot you can get either on its own or with a series padding resistor will give you some control.
It's an odd feedback type control- you might get away with 10x the capacitor and a 1meg pot.
20th Jul 2018, 8:59 pm | #6 |
Without the option for an exact replacement, can you explain in more detail what components I would need to substitute in place of the pot, but keeping the max bass setting. Or maybe a pot and components which would give me a little high end bass control. Sorry for needing precise details but I'm a novice.
20th Jul 2018, 10:28 pm | #7 |
The pots are marked pos log and neg log I am taking it that that neg log is an anti-log ?
That's going to be even tougher to find if that's the case. Cheers Mike T
20th Jul 2018, 11:04 pm | #8 |
Hi Kev,
Have a look at 'Blore Edwards' site, https://www.blore-ed.com/dual-gang-45 . They list dual gang 10 meg log pots from their standard '45' range. They will even make a bespoke pot to your exact spec if you require! I have never needed their services but their name has cropped up on here in the past. Hope that helps Cheers Nick |
