28th Mar 2021, 11:27 am | #141 |
Re: EKCO U122 - Restore or spares?
That makes sense Lawrence.
Donald, I'd try the same bush pin 4 mod then and see. Maybe it works, maybe it doesn't, but it's a quick and easy test |
28th Mar 2021, 11:36 am | #142 | |
So no....you can't add a cathode resistor to the UL41 in the Ekco since the bias arrangements are completely different.
14th Apr 2021, 9:54 am | #143 |
I'll Post an update later on the electronics issues discussed above but meantime I've moved on to address some of the cosmetic challenges with this set.
The case is slightly warped at one of the top back corners (heat damage) while the case grilles are all very much the worse for wear! . The dial glass printing is very basic but in good condition and I am intrigued by the strip of brown paper crudely attached by some black tape. The same brown paper had been used to wrap the dual electrolytic can? Does this brown paper have any particular properties or characteristics, is it needed and if so what would be a suitable replacement? I still have the problems of what to do about the control knobs:- https://www.vintage-radio.net/forum/...15&postcount=1
BVWS Member |
26th Apr 2021, 7:31 pm | #144 |
I've been a bit preoccupied with Bluetooth challenges (!) over the past few weeks but managed to find some time to do some work on this EKCO U122. Some Forum members may remember the problems I was having with the bias on the Control Grid of V4 (UL41) which seemed to creep to just above -ve 3.0V to -ve 4.7V but the readings weren't stable and dropped dramatically when the set clicked or crackled?
As I now know, thanks to Lawrence and others, this EKCO U122 uses grid bias and although the resistors responsible for developing the bias voltage for the Mixer, IF and output valves had been replaced there was no improvement? With the U122 I couldn't work out why the cathode bias on V4 suddenly appeared and then disappeared - this seemed to coincide with some clicking/sparking from the set and I was led to believe (?) that this came from internal shorting within the UL41, a common problem. Further detailed investigations with much wailing and gnashing of teeth showed that the bias issue often coincided with me taking measurements at the neutral tag on the electrolytic dual can! Initially I thought I had a dry solder joint but I reflowed that and still no joy. So disconnected the electrolytic dual can and temporarily bodged-in two 47uF caps and everything worked fine! So what I've done is to re-stuff the dual electrolytic can with 47uF and 32uF Rubycon Minature electrolytic capacitors and the Control Grid bias on V4 is now steady as a rock at -ve 4.38V (MW off-station). How does it sound - well reception on both MW and LW is very good, what little there is up here in Glasgow, the audio quality is more than acceptable when on-station. When off-station, however, there is a lot of background hash along with that almost ubiquitous hum, no doubt caused by the UY41 Halfwave Rectifier? Before I sign off on the electronics side of things I'd to revisit the issue first raised by Lawrence way back in Post #15 - "I might be wrong but looking at the transformer and the data sheet photo's it looks like the primary hasn't been connected for optimum anode load impedance.....9k as opposed to 3k." The connections I currently have to the Output Transformer Primary are to tags 1 and 3. The valve data for this set lists Va = 213V and Vg2 = 76V and I am measuring Va = 218V and Vg2 = 77V - near enough or do I need to try the connections to tags 2 and 3?? I'd still like some advice and guidance in relation to the cosmetic case and knob issues raised in Post #143 above - thanks.
BVWS Member |
26th Apr 2021, 9:36 pm | #145 | |
As I said earlier, the optimum anode load impedance given in the valve data won't be the same in your receiver because in the valve data Vg2 = Va and this is not the case in the receiver so as also said earlier use the taps that give the best result, the various taps should have little effect on the valves DC conditions. Lawrence. |
27th Apr 2021, 12:24 am | #146 |
You may well be picking up electronic hash when the radio is detuned. Almost anything with a switch mode power supply or a processor can generate this.
I don't know of any radios of this type which are completely hum free. |
27th Apr 2021, 10:16 am | #147 | ||
Just for completeness I decided to connect up tags 2 and 3 on the replacement RS Standard Output Transformer - this resulted in a slight reduction in hum and the relevant V4 (UL41) valve pin voltages were measured as: - Pin 2 Va = 230V Pin 5 Vg2 = 88V So higher than the measured voltages when connected to tags 1 and 3 (Va = 218V and Vg2 = 77V) but slightly less hum. Is it possible to source and fit an Output transformer of the hum reduction type? Quote:
I appreciate that a certain level of hum and background noise is to be expected but it just seems a bit worse than usual with this set? Not going to lose any sleep over it so I'll probably just move on to tackling the cosmetic case and knobs challenges.
BVWS Member |
27th Apr 2021, 10:25 am | #148 |
What is an output transformer of the "hum reduction type"?? I thought this was the role of the HT choke or smoothing capacitor. Are we talking about AC ripple hum here or something else?
27th Apr 2021, 10:55 am | #149 | |
Lawrence. Last edited by ms660; 27th Apr 2021 at 11:07 am. Reason: extra info |
27th Apr 2021, 12:24 pm | #150 |
Thx Laurence
27th Apr 2021, 3:18 pm | #151 |
To hopefully wrap up the issues associated with the Output Transformer tags and the optimum anode load impedance we have ended up with the following:-
1. Service Sheet : Va = 213V and Vg2 = 76V 2. Tags 1 and 3 connected : Va = 218V and Vg2 = 77V 3. Tags 2 and 3 connected : Va = 230V and Vg2 = 88V Although 3. gives us less hum, the valve pin voltages for V4 (UL41) are higher. So to what extend would that be over-driving the output valve, knowing how problematic the UL41 can be?
BVWS Member |
27th Apr 2021, 4:02 pm | #152 | |
Lawrence. |
28th Apr 2021, 12:08 pm | #153 | |
218V x 26.4mA = 5.75W Connecting the V4 Anode to Tap 2 of the Output Transformer I am measuring:- 230V x 26.6mA = 6.11W So it seems that for the higher impedance tap the output power is less which I assume is better for the UL41? But somewhat counter-intuitively this configuration is giving us more hum? Does it matter which way round the connections are at the Primary of the Output Transformer? I have the V4 anode connected to Taps 1 or 2 while the +ve from the smoothing capacitor is connected to Tap 3? @Lawrence - what would you recommend in relation to ' ...some RC filtering between the reservoir capacitor and the load' ?
BVWS Member Last edited by DonaldStott; 28th Apr 2021 at 12:25 pm. |
28th Apr 2021, 12:16 pm | #154 | |
The anode dissipation isn't the same as output power. Lawrence. Last edited by ms660; 28th Apr 2021 at 12:23 pm. Reason: extra info |
29th Apr 2021, 12:19 pm | #155 |
I've not yet fitted a replacement Mains RF filter so it will be interesting to hear what difference that makes, if any, to the hum?
X2 type capacitor of course!
BVWS Member |
29th Apr 2021, 3:08 pm | #157 | |
29th Apr 2021, 4:10 pm | #158 | |
Solving the problem of hum is a bit like chasing unicorns!
BVWS Member |
29th Apr 2021, 4:14 pm | #159 | ||
How did you get on with the RC ripple filter? Lawrence. |
29th Apr 2021, 4:26 pm | #160 | |
Next on my list - just looking at the circuit diagram to decide where to fit the 220 Ohm and a 33uF? I'm assuming the 33uF is an electrolytic?
BVWS Member |
