6th Mar 2021, 1:21 pm | #1 |
EKCO U122 - Restore or spares?
I've recently just opened up an Ekco U122 which, on first inspection, appeared to have been untouched. What I did resolve was the loud clunking that I heard when the set was moved and somewhat alarmingly the Output Transformer had been fixed to the front panel with two split pins, both corroded but now replaced with 4BA bolts, washers and nuts. The mains lead looked to be original twisted cloth but it is in fact three core with the earth wire cut off at both ends!
I opened the plug, sorted out the fraying wires and inserted a 3A fuse but when connecting my test leads to the L and N pins with the switch turned on I was getting 67ohms? Most troubling indeed was the on/off switch - there are 4 tags, two for the incoming L & N and two for the respective outgoing. Unfortunately with the switch either on or off I was getting continuity between any two pairs of tags you may wish to choose - even I knew that something wasn't quite right here! Short detour to resolve the problems with the on/off switch:- EKCO U122 - Faulty on/off switch Meantime, I further disassembled the set and removed the aerial board to allow easier access to both sides of the chassis - some general pictures:- . The Primary of the Output Transformer reads 839ohms (and the speaker crackles) while the Secondary reads 1.5ohms. The speaker itself measures 2.7ohms. Here is a picture of the confusing wiring (to me) associated with the Output Transformer and the Loudspeaker:- Other points of interest are the signs of overheating on R8 (Trader 995) and the 'strange' replacement for V5 (UY41):- . In order to get this set to a stage when I can even consider a Live Test there appears to an inordinate amount of work to be done replacing components and crumbling wiring, notwithstanding a rusty chassis along with repairs to the case etc. Add to that two new bulbs, replacement knobs and a NOS UY41 - but that list could increase if I delve deeper! So I haven't gone any further in case it's a non-starter although this set could be used for spares and repairs?
BVWS Member Last edited by DonaldStott; 6th Mar 2021 at 1:27 pm. |
6th Mar 2021, 1:27 pm | #2 |
Re: EKCO U122 - Restore or spares?
The problems you've encountered so far don't seem at all unusual to me.
At the end of the day it's up to you to decide whether to repair it, restore it or use it for spares. We all have our own way of doing things. One point I'd make is that it's seldom an economic proposition to repair a set. You'll never get your money back, but we don't fix sets to make a profit do we?
6th Mar 2021, 1:31 pm | #3 |
It's certainly been in the wars. The first thing to do is work out what's happening with the dropper and rectifier.
If the case is good, you may be able to find a better U122 with a smashed case, and make one good set out of the two. |
6th Mar 2021, 1:33 pm | #4 |
It seems a shame to scrap it at this stage.
A short cut with crumbling wiring is to sleeve it by cutting one end of each wire. |
6th Mar 2021, 1:53 pm | #5 |
First thoughts suggest the the UY41 has been replaced with a silicon rectifier with a limiting resistor. The 'polo-mint' RS dropper sections have probably been used to replace the heater of the UY41 since they could be made to 'plug in' to the valve socket across the heater pins.
It's up to you what you do but I think it's perfectly restorable to original if its just a question of removing the polo-mints and silicon rectifier, rewiring the AC feed back to original and plugging in a new UY41. Then it should be the usual job of recapping and fault-finding as required. Not really all that much extra work.
6th Mar 2021, 2:07 pm | #6 |
Looks like a fairly normal/easy restoration to me. I wouldn't say that drop of wax is indicative of a problem with R6.
There's actually never that much worthwhile spares to be salvaged from an old radio, certainly nothing much that can't be brought new. Regards David
http://www.youtube.com/ My Nixie Clocks |
6th Mar 2021, 2:17 pm | #7 | |
Imagine the achievement when you get first sound. But it’s your choice depends where you get your enjoyment. John |
6th Mar 2021, 2:48 pm | #8 |
The output transformer looks very similar to a Radiospares replacement if it is and it doesn't have a hum cancelling winding then something is likely to have been fudged, Radiospares did do a "choke" output transformer.
Lawrence. |
6th Mar 2021, 5:12 pm | #9 |
Here is the top view of the Output Transformer with the Radiospares logo clearly visible:-
The four Primaries are labelled 1. 2. 3. 4. while the five Secondaries are labelled F. A. B. C. F. And the side view:- I love the text 'Instructions Enclosed' So well spotted Lawrence - it's a Radiospares 'Standard Output Transformer'.
BVWS Member |
6th Mar 2021, 5:45 pm | #10 | |
The Secondary tags labelled F are "dummies", provided as anchoring points for field connections etc. See here: - The F tags have been used for the two HT smoothing resistors which also appear to be be 'newer' replacements for R20 3.3kOhms.
BVWS Member |
6th Mar 2021, 8:31 pm | #11 |
It has certainly been got at, but nothing that can't be sorted out, I have restored worse!
What condition & colour is the case in? Mark |
6th Mar 2021, 9:07 pm | #12 |
Go on, give the poor thing a chance to live again! They don't make em anymore, and every one scrapped is another lost forever, OK, there's loads of them about now, there's 2 of them looking at me now! One green, one white. I revived one of them, it's not a bad set! They look pretty cool too... Basket cases are the most fun to work on, the worse the better! I'm currently working on an old 405 line Philips TV that was dumped in a loft for a very long time, damp and neglect have taken their toll, but it's slowly coming back, I'm just about to try adding a strip of veneer to the bottom edge of the cabinet, if that looks ok then I'll try french polishing it, The chassis is nearly functional too.
Good luck with the restoration! Lloyd |
7th Mar 2021, 11:56 am | #13 |
Thanks for all the encouraging Posts - it was never likely that I was going to walk away from this challenge but I was just curious to know if there were any obvious showstoppers? Also interested to know of any known 'quirks' with the U122 that I need to look out for?
I've now satisfied myself that I understand the wiring around the Output Transformer and Loudspeaker, both working, and will move on to look at the silicon rectifier and dropper. In Post #5 above, Sideband made it all sound too easy " ... it's perfectly restorable to original if its just a question of removing the polo-mints and silicon rectifier, rewiring the AC feed back to original and plugging in a new UY41." I need to take a step-by step approach to ensure that I understand what is being changed and why. For example, what is a polo-mint and why do they need to be removed? I've never encountered a silicon rectifier of this type and can't make sense of the under-chassis pin arrangements, particularly the heater connections if I'm going to replace it with a NOS UY41? In Post #1 above I attached a photograph of the silicon rectifier and there are two (newish) blue wires running to the pins on the valve base - not sure what those are? The dropper is cracked in a couple of locations and some of the insulation has dropped off - is this a problem? I'll check the resistance readings later but it's very grubby and needs cleaning before I get out the DMM! As with most sets I've restored I've found it very useful just to spend time looking at the wiring and trying to understand the connections - especially comparing it with the circuit diagram. It's especially difficult with sets such as this which have been 'got at' in the past as you are trying to mentally undo what was in the mind of the 'Phantom Twiddler'!
BVWS Member Last edited by DonaldStott; 7th Mar 2021 at 12:22 pm. |
7th Mar 2021, 12:13 pm | #14 |
If the UY41's valve holder is ok it's easy to revert back to UY41 rectification, just refer to the schematic, the substitute heater resistance should be removed and the silicon rectifier should be removed along with any additional surge limiter resistance that might have been fitted in conjunction with it.
Lawrence. |
7th Mar 2021, 1:02 pm | #15 | |
Lawrence. |
7th Mar 2021, 1:49 pm | #16 | |
Which value is correct for optimum anode load impedance and why? Meantime I'm focusing on the Dropper and have measured the values and traced the connections - shown in this diagram: - A bit intrigued by the 'flying' 150Ω resistor and BY127 diode in this picture: -
BVWS Member Last edited by DonaldStott; 7th Mar 2021 at 2:02 pm. |
7th Mar 2021, 2:24 pm | #17 | ||
The 150 Ohm resistor is an extra limiter resistor that was fitted with the BY127 as I suggested earlier. It would have been fitted as a substitute for the UY41's internal resistance so as not to increase the HT due to the lower forward resistance of the BY127. EDIT: Forgot to add that back in the trade in the old days I would have fitted a coil of wire between the limiter resistor and the anode of the silicon rectifier. Lawrence. Last edited by ms660; 7th Mar 2021 at 2:34 pm. |
7th Mar 2021, 3:11 pm | #18 | |
So if I'm putting back a UY41 then I can do away with the 150Ω resistor and BY127 diode?
BVWS Member |
7th Mar 2021, 3:17 pm | #19 |
7th Mar 2021, 3:50 pm | #20 | |
The modification to replace the UY41 probably worked but there would be greater stress on the reservoir capacitor so it is better put back to original. |
