18th Jan 2015, 9:25 pm | #1 |
Power Adapter for BT Robin cassette answering machine
Hi everyone,
I picked up a bt robbin answering machine from our local junk shop. The machine is from around 1985 and came with its origional instruction book. The problem is, that it doesn't come with a power adapter. There doesn't seam to be any info anywhere to say what voltage or milliampage the adapter should be. I do have a multi-end multi-voltage adapter that I could use, but unsure what to set it to. Does anyone have any ideas? Thanks so much, Tim |
18th Jan 2015, 9:34 pm | #2 |
Re: power adapter for BT Robbin cassette answering machine
I think it is 12Volts BUT double check and also wether the centre pin on the machine is Positive.They do not take much current.
Used to have one of these and apart from reworking loads of dry joints it was ok. David
18th Jan 2015, 9:40 pm | #3 |
Wow! That was quick! Thanks David. I am completely blind, but I did ask someone a while ago whether it said posative or negative on the machine, but they couldn't see a marking that said either. How would I find this out for sure?
Thanks so much for your help, Tim |
23rd Jan 2015, 3:57 pm | #4 |
Re: Power Adapter for BT Robin cassette answering machine
Can you get inside and look for helpful electrolytics?
23rd Jan 2015, 4:23 pm | #5 |
Normally Positive centre pin but check,if you meter a positive side of a capacitor to the centre pin it should prove it.
23rd Jan 2015, 5:07 pm | #6 |
There is a Robin on Ebay at the moment. Perhaps the seller would answer your question.
Al
I won't tell you how I discovered that. |
