Old 8th Apr 2019, 9:21 pm   #21
ms660
ms660's Avatar
Default Re: Rescued Test Equipment
I once watched some power engineers in Scotland fixing storm damaged lines up there on the West coast in the kind of driving rain that turns your face red in about 1 second, tough crew for sure, tracked vehicles and Unimogs as I recall, I also figured out why lots of road works etc were abandoned at a certain time of the year, wasn't due to storms either, I thought the interior of Canada was bad enough, I got caught out up on Skye when the oil filter seal blew on my old Landrover….almost bitten to death fixing that one, anyways enough of that.
Lawrence.
ms660 is offline
Old 8th Apr 2019, 10:10 pm   #22
Herald1360
Herald1360's Avatar
Originally Posted by David Simpson View Post
But, its the pdf download scan of the original Every Ready I'm needing - to wrap around an RS, or Varta modern version. As you can see from my picture, the original battery's cardboard is too far "manked" to re-stuff.
Any use?
https://www.vintage-radio.net/forum/...35&postcount=5
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 9th Apr 2019, 9:03 am   #23
ex 2 Base
Morning David, I note your knowledge of Arabic and of course you radio knowledge as well. Good to know some people appreciating old test gear, how ingenious folk were years ago. Also are you aware, Shuft to a man Shufti to woman. Ted
ex 2 Base is offline
Old 9th Apr 2019, 9:55 am   #24
David Simpson
Ted, Shufti Zube, Shufti Cush, if my memories of a brief detachment to Bahrain & Shajah are correct. Nay munta & Imshi were other words learnt.
Many thanks to Herald 1360 for the link.
Lawrence - if it was the late 70's/early 80's when you witnessed poor HEB guys up on the West Coast in the rain - one of them could've been me !
Regards, David
David Simpson is online now
Old 9th Apr 2019, 1:05 pm   #25
Malcolm T
Everything is worth collecting to save it from these trendies who understand nothing about its function or value and commence to turn it into art.
Great for education and instructional workshops in technology.
Problem is how big is your warehouse !!!
Malcolm T is offline
Old 24th Apr 2019, 2:10 pm   #26
David Simpson
Well folks, its been a long haul. Finished at last. I've tried out the capacity measurer out briefly with a couple of lengths of wire about 10 yards long, and one "tunes"(by moving the probe along the resistance wires) it for minimum "buzz" in the phone. However, this is a long distance measurer, and I haven't sufficient coils of wire to yomp over neighbouring fields, & walloping in temp earth rods, etc.
Fingers & wrist has been overworked, restoring the crud encrusted mahogany case. The bespoke latchable hinges were shot, so replaced with a piano hinge.
On to the next manky item - -
Regards, David
Name:	Capacity Measurer (j).jpg
ID:	181778   Click image for larger version
Name:	Capacity Measurer (k).jpg
ID:	181779   Click image for larger version
Name:	Capacity Measurer (l).jpg
ID:	181780   Click image for larger version
Name:	Capacity Measurer (m).jpg
ID:	181781   Click image for larger version
Name:	Capacity Measurer (n).jpg
Old 24th Apr 2019, 2:17 pm   #27
Craig Sawyers
Craig Sawyers's Avatar
Looks great! What a transformation.
Craig
Craig Sawyers is online now
Old 24th Apr 2019, 5:33 pm   #28
Pamphonica
Pamphonica's Avatar
Ah - now that IS a lovely bit of kit now. Well done maestro!
Many moons ago I bought a "wooden cased ammeter" from ebay for £7.99. It was covered in paint spray and crud but looked vaguely familiar.
I used the meths and wire wool plus oil treatment and a bit of buffing of the front panel and it came up beautifully. It even worked. And yes, it was familiar-looking.
I found out from Peter Munro, the Avo guru, that it is an "Original" Avo from about 1925!
One of only a few left...
So glad it once again looks the part. Original patina but no crud or paint.
Jeremy, G8MLK, BVWTVM Friend, VMARS, BVWS Secretary.
www.pamphonic.co.uk www.bttt.org.uk
Pamphonica is online now
Old 24th Apr 2019, 6:05 pm   #29
Radio Wrangler
Radio Wrangler's Avatar
That shows what a lot of TLC can do. Very satisfying. The woodwork glows!
So now you just need some suitable period capacitors... um, condensers to measure with it.
It looks like it ought to be sitting in a glass display case.
Radio Wrangler is offline
Old 24th Apr 2019, 8:53 pm   #30
David Simpson
Thanks Guys for the kind comments. However, compared to some of the fantastic restorations in the BVWS Bulletin & VMARS Signal Magazines over the years, my efforts are pretty mediocre.
What I would suggest, in encouraging others to have a go at cabinet or wooden case restoration, is to practice on gash bits of Oak or Mahogany, or Redwood first. Broken bits of furniture can be scrounged from dumps & skip sites. Save bits of old smooth shirts/blouses etc. Practice different methods of dirt, stain & manky varnish removal - mild soapy water, White Spirit, Turps, Meths, & so on. Try different grades of sandpaper & wire wool. Just buy wee tinnies/bottles of woodstain, scratch cover & polish to start with.
Its taken me years to be half proficient. Ask advice off old joiners & carpenters. One old boy showed me how to make beeswax(in the tobacco tin, bottom centre).
Regards, David
Name:	Cloots & Polish.jpg
