Old 19th Jan 2020, 5:43 pm   #1
jdavis6809
Default Levell TM11 Multitester User Guide / Circuit
Hello,
I have a Levell TM 11 multitester
The meter movement is ok because it displays battery level
When knob switched to zero, meter cannot be zeroed
When knob switched to DC+ meter movement hard left
When knob switched to DC- meter movement hard right
Without being able to zero there no point in doing other tests
Anybody got user guide / circuit ?
How to use it may be helpful some settings not obvious
thanks
john uk
jdavis6809 is offline
Old 19th Jan 2020, 10:19 pm   #2
gezza123
gezza123's Avatar
Default Re: Levell TM11 Multitester User Guide / Circuit
jdavis6809
Hi john uk
Ihave this Original, will try and see if can put it on forum for you.
Let me know if you get it, if not will need your Email.
gezza123
gezza123 is offline
Old 19th Jan 2020, 11:40 pm   #3
jdavis6809
hello gezza123,
pdf ok thanks
looked at other posts not showing pdf
thanks again everything looks ok to fix it
regards
john uk
Old 19th Jan 2020, 11:52 pm   #4
Andrewausfa
Andrewausfa's Avatar
gezza123,
Thanks very much for sharing this, I've been searching for ages for, at the very least, a circuit as I have a non-worker. I've also got a worker in its original leather case.
Thanks again - Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 22nd Jan 2020, 9:54 am   #5
Chris55000
Hi!
. . .And from me also!
Chris Williams
Chris55000 is offline
